Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
Flashing F1 code, how do I fix - Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
  • 784 Answers
F1 code is water leaking. 1- Dry out the bottom housing to make the F1 disappear. 2- Replace Actuators and the lid seal to prevent this happens again. The actuators is pulling down from the left and right sides to hold the top lid against the top surface of the tube groove to seal water from coming out during the wash cycle. When actuators are bad, they can not hold the lid down or make the lid tilted to one side hence the leak is coming. When the lid is tilted for a long time the seal is distorted then it has to be replaced since it is out of tube groove shape
Posted on Dec 29, 2009
DD603 Dishwasher bottom drawer flashes F2 with a spanne. What does this mean?
Posted on May 20, 2010
My kenmore elite washer, model #110.27092600 flashes an f1 error code when filling
F1 code = Primary Control Failure. Replace the machine/motor control assembly.
Call 1-800-659-7026. That machine has a recall for the control board and if your machine is in the recall they will fix it for free.
Jul 30, 2011 | Kenmore Washing Machines
I just bought a 2008 Suzuki B-King and it keeps flashing the fi code and the fi light is on. It has aftermarket exhaust on it, how do I stop it from flashing because it wont let me see the trip meter at...
Take it to the shop and have them read the error code. The flashing is an error code and wont stop till you fix the problem or shop resets the code for you... That is my experiences with these issues....
I hope that this helps you and please do not forget to rate/vote and place a testimonial on my advice.
Wicked Angel
Nov 19, 2010 | 2008 Suzuki B-king
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
F1 code whirlpool
whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
CODE f1 FLASHES , I unplugged the oven for 1 hour and stil comes back with the f1 and beeps
f1 code on most ranges are erc failure. only way to fix is to replace the oven control board
Nov 05, 2009 | Kitchen Ranges
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My dishwasher keeps flashing F1 error message
The f1 code is caused moisture in the electronics part most likely in the door.see if there is any way that you can see where moisture might get in and plug that spot up. In the case of the f1 code when not using the dishwasher leave the door propped open to help dry out the electronics.
Nov 18, 2008 | Fisher Dishwashers
Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Jan 05, 2008 | Sharp AR 163 Copier
F1 Error Code
try fix at http://www.fixya.com/howto/h155060-dreaded_f7_error
this is a common error and easily fixed
Dec 19, 2007 | GE Profile JTP18 Electric Single Oven
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
445 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
