Question about LG Dishwashers
LE error message
LG dishwasher Model LDF 7810BB/LDF7810ST rinse mode LE error message
  • 3,230 Answers
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Good Luck!!
Posted on Mar 27, 2010
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
Ldf7810st is not draining and shows error code LE
most common problem is bad sensor in main motor
replace main motor
Aug 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LE error code
check you inlet and outlet water hoses, check for leaks and blockages
Jun 29, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Repair code LE and bottom is flooded
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
Jun 18, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Two days ago my LG dishwasher model lDF 7810BB worked fine. Yesterday I loaded it and the display panel will not light nor show any sign of power. I check the circuit breaker several times and all other...
Check for voltage with a multimeter at the wires very near the front, just behind the kick plate. Follow the incoming electrical wire in and remove the little plate the covers the wires/wire nuts. I have seen wires that appear to be connected properly but the circuit is open.
Or, even though the circuit breaker is not switched open, the circuit itself, supplied to the front of the dishwasher is not live/hot.
Good Luck!
Mar 08, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Ldf 7811ST dishwasher
ok if that's the correct code then it will likely be a communication problem between the motor and control panel ie loose wire broken wire resistance on the touch pad control ribbon which can be cleaned with a pencil eraser by the way or something along those lines the control just thinks the motor is bad because it cant communicate with it maybe
Mar 23, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
335 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
