Question about GE Profile Spectra JGBP85 Gas Kitchen Range
Stuck warming drawer
We can't open the warming drawer at the bottom because the broiler pan is wedged in and prevents the drawer from opening. We need to get at it from above. Is there any way to remove the lower burner and the floor of the oven (the shiny steel part under the lower burner) so that we can get the broiler pan out?
  • ltarris Jan 30, 2009
    i have the same problem. i'm trying to figure out if there's a way to remove the floor of the oven to get at the top of the warmin drawer
    Top Expert:
  • GE Master
  • 49,180 Answers
Sadly there is no way from the top . only thru the door .
Posted on Nov 19, 2017
5 Suggested Answers
  • 473 Answers
SOURCE: Warming Drawer stuck
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Posted on Oct 25, 2007
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Posted on Nov 15, 2008
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Posted on Jun 08, 2009
  • 56 Answers
SOURCE: lower oven burner has a yellow flame,broiler flame
Just Live With It
Posted on Aug 07, 2009
How to take apart the drawer to get stuck pans out
Ruler, spatula, bend wire coat hanger, insert between oven bottom and drawer and move back and forth in attempt to dislodge object. Note sometimes objects fall behind the drawer.
Nov 26, 2017 | Maytag PER5510 Performa Electric Kitchen...
Drawer wont slide and dishwasher does not work
please provide the model number of the dishwasher so that I can identify the type of lid seal it is using. Usually the lid seal actuator motors are stuck and prevent drawer from opening. You could force it open with a slight tug. Otherwise turn the mains power off and on and see if it makes any difference. Need to check the lid seals for damage otherwise it may leak in future and cause flood switch to trip.
Dec 07, 2012 | Fisher and Paykel Dishwashers
Display F1 want do anything else
An F-1 is a fault code that comes on when you have accumulated at least 1/8 of water in the base pan under the drawer. You have two options, first one you can unplug unit from the power source and allow the air in the room to dry it out or while unplugged you can remove the drawer by releasing the tabs on the bottom of the lowest drawer and slide out the drawer to remove the water. There are a couple of different models and you didn't leave a model number to allow me to send diagrams too.
The true fix is to determine why the base pan is collecting water, here is a couple of common issue that could create this problem, drawer too full and seal to drawer did not seal, too much soap, bad seal to lid (that covers drawer during wash) or the hoses in the back of the drawer have came loose and prevent the lid to lower and cover the drawer.
I hope this helps...
If you need more help let me know and I can give you pictures, parts lists, and step by step instruction with the model number located on the rim of the upper drawer open..
Jul 15, 2011 | Fisher and Paykel Dishwashers
The oven would not light, the broiler works and the stove top but the oven would not light up
the ignitor bar underneath the bottom of the oven bottom is bad and you need it replaced,remove the pan drawer to access the mounting screws and wires to it
Nov 26, 2010 | Maytag CWG3100A Gas Single Oven
Oven is smoking
the oxygen vent needs to be open about half, that vents is at the bottom part of the burner, or some times is facing you, you get to it from the broiler drawer. you have to remove that drawer to see it.
Dec 09, 2008 | Kitchen Ranges
Bottom drawer locked (stuck) open
fisher and paykel sent me a solution - turn off at wall and unplug then turn back on. The dishwasher reset itself and the drawer unlocked.
Nov 24, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85 Gas Kitchen Range Logo
314 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
