Memories on TV unlock code not working
Purchased the unlock code for Memories On TV a year ago. Worked fine in June when I did a movie for my Grandpa's 80th birthday. Now I am trying to do my grandma's movie and it keeps asking me for the code again. I have tried to input it but it says invalid code. Don't understand what is wrong, and there is no way to email nova development on this issue through their website.
SOURCE:
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
Bajanguru
  • 7752 Answers
SOURCE: unlock code for motorola l2
yes there is a way ....press the menu button key....then it will ask you for the security settings enter the default code 000000.
Posted on Jan 16, 2008
  • 3 Answers
SOURCE: Photo Explosion Deluxe
Thank you for contacting customer service. The MPEG-2 Plugin for Memories on TV allows you to burn discs in SVCD format on a CD-ROM. This is a superior quality to the standard VCD option which is included in your software. The MPEG-2 will also let you burn in MPEG status, which permits you to burn your files to a DVD-ROM. Not all players support the video formats so please be sure to check your reference material to see what your player can support.
The price for the MPEG-2 Plugin is $12.95. To download, please go to http://www.novadevelopment.com/products/us/mtw/default.aspx You will receive your code via email shortly after purchase. . Please allow up to 24 business hours for your order to be processed.
Posted on Feb 06, 2008
  • 3 Answers
SOURCE: unlock code
SOURCE: Burning movie using memories on TV3
If you burnt a DVD + , try getting a DVD - and burn to that or vice versa. Some DVD players play both the DVD + and the DVD -. Other DVD players will only play one of the two types of discsl
I burn all mine to a DVD +.
Posted on Oct 22, 2008
We have a sony bdp 300 DVD. We updated the firmware several months ago and all the movies worked fine. However, now it will play just fine during the previews but when we play the movie, there is no audio....
Hi
This certainly looks like a potential firmware issue especially if the Audio is there on the previews. There are reports also of recent firmware updates causing problems on some other Sony BDP units.
You might want to try a Blueray cleaning disk which you can purchase from any good Audio store first to ensure there is not a problem with dirt on the lens that may be causing this. Simply insert and play like a normal disk and it provides a cleansing action to the lens.
Otherwise my advice is to contact Sony directly to discuss the matter and find out if there have been any recent firmware issues.
The most recent update for your unit is firmware version 4.9 and this was released on 12th June 2009
The support phone number for Sony Blueray Players is 239-768-7547
Hope this helps. Please do rate this answer. Many Thanks.
Sep 05, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I purchased my tv 2 years ago. Watched it
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Hi, I have a Panasonic W32D2DP its about 5 years old. It worked fine until about 3 weeks ago. It started cutting off and going to standby. It worked fine after for a few more hours, then would do it...
It's going to be cheaper to buy a new TV. Once you get this problem solved, another one will pop up. The parts for a TV that's 5 years old are not going to be cheap. Most TV repair shops stop carrying parts after 4 years, & the manufacturer stops making them after 7-10 years. With a semi-major purchase like a TV, it's best to purchase an extended warranty. ipmart. com offers a cheap repair manual. You'll be suprised how expensive repair shops can be when it involves "out-of-warranty" work.
May 08, 2009 | Televison & Video
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Jul 23, 2008 | Nova Development Photo Explosion Deluxe...
DVD player won't recognize movies in drive D
It may be a case of downloading "CODECS" for the the software to be able to recognize the new movies. It's an anti-piracy technique that require frequent updates to view DVD's on computers to try to eliminate copying.
Mar 27, 2008 | E-Machines eMachines Refurbished EMA...
Unlock code
What a freaking waste of time. Worked on creating a video to burn to DVD with Memories On TV only to find I need a code to burn it. Thanks for nothing Nova. Arrgh!
Feb 01, 2008 | Nova Development Photo Explosion Deluxe...
Computers & Internet Logo
743 people viewed this question
Alun Cox
k24674
