Question about Salton IBFS3S 12 in. TV/DVD Combo
PACE DC701X - ATSB tuning message
I keep getting a message that says "The ASTB needs to download a new software. This could take a few min..." and then "tuning to frequency" and keeps doing it over and over. I am just hooking up to cable here for the first time - not sure how to get this to finish or go away and get to cable.
PACE DVR. Please Help! Anybody
Try to google the message
May 13, 2013 | Televison & Video
No sound no picture. message: V1.24 Pace Vegas 614 Loader The ASTB needs to download a new software. This could take a few minutes, please be patient. Tuning to frequency LKC: Done ...
Are you using the cable/Sat box? That sounds like you have the problem with your Sat box or the cable box, not the TV problem. It is trying to update the firmware.
You should contact the hardware provider.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 11, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
Message apple application needed to open itunes
make sure that you have all the software that you downloaded with i-Tune such as Quicktime this is needed to run i-tune to work 100% you Will have to download the piece you are missing or save you music to windows uninstall and reinstall i-Tunes.
May 26, 2010 | Apple iTunes
Ipod Touch isn't recgonize in Tune Tools 2
As you mentioned its showing as Camera that means the software you downloaded from internet Tune 2 is not supportable by Ipod.
Please go through the URL:
http://support.apple.com/kb/HT1386
I hope it will help you solve this problem
Jul 30, 2009 | ValuSoft Tune Tools for iPod Full Version...
Not able to get my auto tune installed right
Hi, are you using Pro Tools as a host? This may happen if you have old and/or incompatible plug-ins in the Plug-ins folder. In one case, older versions of D-Fi and Maxim caused the error message. The first step is to move your entire Plug-ins folder to the desktop (or to the Plug-ins Unused folder) and relaunch Pro Tools. The Digidesign Plug-ins folder is located in C:\Program Files\Common Files\Digidesign\DAE. If that works, then you need to go through your Plug-ins folder and determine which plug-ins are old or incompatible and either update them or remove them.
If that doesn't work, then it is best to remove Pro Tools and all PACE files completely, then reinstall Pro Tools.
Feb 02, 2009 | Antares Auto-Tune 4 TDM Production Suite
Pace i.3.33
get a multimeter and connect the black probe to the metal part of the closed box, connect the red probe to the middle pin hole of the sattalite input connector and tune into a channel
You shold be getting around 13v +/- 2v
OR
+18v +/- 2v
If you are not getting this your tuner has failed.
Jun 07, 2008 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Needs to download new software
Hey there bethymofo, the problem is with your cable box. Your TV is fine. You should contact your cable provider but most likely result is to bring in for a new replacement. Good Luck!
Mar 25, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
Onkyo tx-nr801 net tune setup help
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Nov 15, 2007 | Onkyo TX-NR801 Receiver
Distances are WAY wrong.
hi
before you start running make sure you take the unit outside into the clear for a few minutes, dont just start running from inside a building or a new location
erase the track log if you can so that the data is only resuts from the current run
make sure you check the signal for the next few runs
(also run a few extra for me)
D
Oct 03, 2007 | Garmin Forerunner 301
Salton IBFS3S 12 in. TV/DVD Combo Logo
1,269 people viewed this question
Top Salton Televison & Video Experts
Marvin
Marvin
Are you a Salton Televison and Video Expert? Answer questions, earn points and help others
