Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The f7 number keeps beeping on my GE profile range. i am assuming the oven is no longer working as nothing happens when i push the bake button. the most annoying problem is that f7 beeps all the time; it has now almost two weeks since it started. is there any way to stop the f7 beeping?
    Scholar:
  • 68 Answers
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
you have a stuck button on the key pad you will need a new control board to fix this.
goto http://lartoday.com/order_parts.htm , enter your full model number and search for control
levi
Lebarchrigen Appliance Repair
Mt. Holly, NJ 08060
www.lartoday.com
Posted on Dec 11, 2009
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
F7 code keeps flashing, nothing on keypad works. I can use second oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will...
After much searching, I have found that you have a faulty keypad.
The recommended solution is to unplug the oven, or shut it down at the fuse box, and then remove the faceplate where you can then remove the keypad, and clean the connectors with an eraser, as well as the ribbon that connectes the keypad with the oven.
I hope this helps out.
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
May 12, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
410 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
