Question about Cameras
I have a Canon A1000 IS PowerShot that seems to be ''stuck''. If I turn it off then on, it goes back to the zoom of the last picture taken, I can only view the last picture taken and cannot take any more pictures. It's like a PC freeze up. What can I do? Thanks
    Brigadier General:
  • 11,967 Answers
Remove the card...go into the menu and find "reset"...follow the on-screen instructions.
Posted on Dec 11, 2009
Canon Powershot A1000-IS stuck on zoom plus shutter problem.
hello. If there is a reset, it will show it here in the manual. go to this web address. http://gdlp01.c-wss.com/gds/0300001222/PSA1000IS_CUG_EN_02.pdf hope this helps. Ron
Sep 08, 2009 | Canon Powershot A1000IS Digital Camera
Frozen
You have a stuck zoom switch. The fix will require opening the camera, see the following link. This detailed fix is courtesy xscrewdriver (nice job xs).
Aug 01, 2009 | Canon PowerShot A560 Digital Camera
Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 22, 2009 | Canon Powershot A1000IS Digital Camera
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
Zoom lens stuck
Hummmmmm.......I guess it all depends on how hard the drop was. At this point, you have nothing to lose by tinkering around with it.....but my guess would be that it's taken it's last picture. You might try locating a camera repair shop, or even an independent jeweler. They might could at least take a look at it and give you a second opinion. Hope this helps, and sorry about the bad luck!!!!
Chad
Oct 11, 2008 | Canon PowerShot SD850 IS Digital Camera
Canon Powershot A520 Stuck in View Picture Mode
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Sep 30, 2007 | Canon PowerShot A520 Digital Camera
Canon Powershot A75 problems ________________________________________ I have a Canon powershot A75 Digital camera its about a 11 months old and has a few problems now. 1. zoom doesn't work any more 2....
Having read on a few sites about loose ribbon wires causing problems and having this same problem. I decide to take the camera apart. Taking all the screws out and fidling with the "wires" connecting the zoom control and the photo type selector and the main circ board. I also cleaned the connector from the picture type selector. Then put it all back together the camera works fine again. NOTES... lots of small screws with varying lengths make sure you know where they come from. Took about 1 hour to do.Put back in the order you take apart or the back will not go back on.. Good luck have just saved myself a fortune
Dec 15, 2006 | Canon PowerShot A75 Digital Camera
Cameras Logo
96 people viewed this question
Top Cameras Experts
Steve
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
