Question about IBM PC 300PL PC Desktop
I just upgraded my PC 300PL IBM computer's RAM from 128 MB, to 256 MB on each slot (3 slotes), When i watch videos from my pc, or videos from online sites, The playback is slow and choppy. I was wondering what can i do to get good video playback? Thanks.
  • da4791 Dec 17, 2009
    I noticed that when i play 320 resolution videos from my hard drive, they play perfect even in full screen. But when i play videos of 630 or 720 resolution, the video doesnt play right, it messes with my screen, colors and jumpy graphics, cant watch it.
    Do you think i can upgrade my video card? what do you recomend?
    Thanks.
    Brigadier General:
  • 10,406 Answers
The problem is that the video-player on your computer is "starving" for audio/video, because your download-speed is not fast-enough to "feed" the stream.
So, when a video starts to play, click PAUSE, and wait for the download to proceed for a while; then, click PLAY, to view the already-downloaded stream.
Posted on Dec 11, 2009
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Does Toshiba Portege 3490CT ram can be bigger than 128. If so adv availability & selling outlet please.
The motherboard has 128 MB memory (soldered on board). However there is still empty slot for further upgrade. You can install another 128 MB PC100 SDRAM memory to get maximum of 256 MB.
CompQ
May 09, 2010 | Toshiba Portege 3490CT Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I noticed that when i play 320 resolution videos from my hard drive, they play perfect even in full screen. But when i play videos of 630 or 720 resolution, the video doesnt play right, it messes with my...
try using a new player...try Nero Showtime...and install latest codecs...."ffdshow" codec is good...search in google and install...
after install shutdown and restart...
Dec 17, 2009 | IBM PC 300PL PC Desktop
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I have IBM 300pl. And it has strange fan problem.
A fan that no longer works will cause a heat problem. While it may not cause a complete failure, it can cause some strange things to start happening. Your best best is to shut the PC down and remove the cover. Restart the PC an determine which fan(s) has stopped working.
At this point, you can either 1) contact IBM for a replacement fan or 2) remove the fan yourself and google the name and model number of the fan to find a direct replacement and either order online or 3) visit a local PC repair shop to buy a replacement fan that matches the defective one.
Buying direct from IBM will probably cost the most, but will be the exact type needed for your PC. Buying locally will probably be cheaper and faster, but may not be an exact replacement unless it is the same model, etc.
When calling IBM you'll need the computer model, serial number and any other identifying numbers on it for them to help you out.
Sep 18, 2009 | IBM PC 300PL PC Desktop
Doesn't detecting ram
The problem is either:
The ram is not compatible with your system
The ram is faulty
The motherboard is faulty
The power supply is faulty
I suggest that you try the following:
Blow the computer out with canned air, especially the ram slots
Try different ram.
Apr 14, 2009 | IBM Computers & Internet
IBM PC 300PL PC Desktop Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
