Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Connecting a mansfield whirlpool tub pump don't know the model number pump is in the floor and tough to get to. there are 2 cords hanging out. 1 male end and 1 female end. When I plug in the male end, the pump runs all the time can't turn it off
    President:
  • 704 Answers
Hello Joe, Typically when you have a whirlpool type tub, there is either a built-in air switch on the tub that will turn the tub motor, on and off, or the tub needs to have a wall switch to turn it on and off.
The switch has to be located so it is at least a minimum distance of 3-4 feet from the edge of either a tub or shower stall, and it must be connected to a GFCI protected circuit. Normally any whirlpool tub requires a separate dedicated 20 Amp 120 Volt AC circuit for proper operation and to meet code.
I believe that the female plug is for an optional, in-line heater that can be installed into the tub unit. You should be able to check the installation manual that came with the tub to verify the proper wiring required for your specific unit and model.
I would contact the manufacturer to get a copy of the installation guide and instructions for your model, so you are certain that it is properly installed and the wiring you are using meet the NEC (National Electric Code).
Here is a link to the Mansfield web site with some FAQ's and their phone contact information.
http://mansfieldplumbing.com/v3/support02-03.html
I hope you find this Very Helpful and best regards!
Posted on Dec 11, 2009
Testimonial: "Thanks I will do that I can't find my manual so I will try to get one from the website Thanks again "
What is the motor model for a sabella whirlpool tub g934?
Look on the pump under the tub and you will find the model number of your pump.
Each model of bathtub has had many different models and brands of pumps attached to it.
The only way to know what the exact replacement pump you will need is for you to look on the existing pump.
Rod
US Parts Center
May 31, 2014 | Jacuzzi Sabella Collection Whirlpool
I have crane whirlpool tub model #2326WL51 needs new pump and touch pad
Need to know the model number of the pump in order to find the correct panel on the top of the tub.
send to: uspartscenter@gmail.com
Rod
US Parts Center
Apr 04, 2014 | Crane & Co Home
Whirlpool Picker male female
A hardware store, a home center (such as Menard's, Home Depot, Meijer, Lowe;s, etc.), or an appliance dealer should be able to supply you with the part you need.
God bless your efforts.
Jul 03, 2017 | Whirlpool Refrigerators
I have a Prowler 720 pool cleaner. While the light comes on the device does not move, the fan on top is not spinning. I'm assuming that the drive motor is not working. Since the mechanism is basically...
The problem may be simpler than you think, Patrick. The robot's power cord must be plugged into the power supply port in a particular way. The male prongs on the robot's power cord are numbered, 1 through 4. Each of these male prongs must be plugged into the power supply port's corresponding number (e.g., 1 must be plugged into 1, 2 into 2, etc.). Do anything else and you get a motionless robot. I hope this helps.
Oct 20, 2013 | Pentair Prowler 720 Pool Cleaner
Jets will not turn off
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Apr 25, 2013 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
How do i empty my air conditioner? it has a hose that comes out of the bottom with a plug, if i remove the plug water comes out slowly. there is another plug about 1/2 way up the unit that if i remove...
Run either to a floor drain or connect a small pump to the lower one and pump the water up to a bucket or other drain ... a bath tub for example.
Why is there two? I don't know. Did you get a owners manual when you purchased this device?
I hope this helps you Suzie.
Jul 11, 2011 | Heating & Cooling
I have all Kohler shower heads with 1 inch pipes; none of the currently available products, all at 1/2 inch pipe connections will fit; is there a 1" to 1/2" reducer piece available; Kohler does not have...
their out there 1 female to 1/2 male reducer u can also check for chrome offset reducers used in the antique conversions such as for faucets for clawfoot tubs and the old farmer sinks
May 05, 2010 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
on mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Oct 04, 2009 | Whirlpool Home
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
829 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
