Question about LG Computers & Internet
I have nothing on the monitor. The laptop is on. It is plugged in. But there is nothing on the monitor. The computer is just about 2 years old has has worked very well until now.
    Sniper:
  • 65 Answers
Couple of diagnostic steps to try here.
1. Remove the battery and AC adapter then plug back in the AC adapter only and power on the system.
2. If that does not work check to make sure that the memory is properly seated and is functioning. If you have 2 sticks try alternating sticks.
3. If that still does not resolve the issue attempt to display laptop on an external monitor if it does then you may have a bad lcd.
4. slightly tilt the lcd to see if there is a very dim picture. If this is the case then it would need a new inverter.
5. if all of these steps fail you may want to take it into a local shop and have it diagnosed. It will probably be pretty grim news but every now and then there could be a loose piece that is shorting out the board.
hope this helps.
Posted on Dec 11, 2009
Samsung r519 not booting, black screen but working
Plug in an external monitor. If you get display then either the screen is bad or the inverter.
If you get nothing, try removing the memory and booting the computer. If you get BIOS and it starts beeping one or more of the memory modules is bad. If you still get nothing then you will want to replace the motherboard.
Dec 15, 2012 | Samsung R519-53S Notebook
When turning the monitor on, I only receive a power saver mode
Does it do the same when it is hooked up to another PC?
Most common failures in 2~3 years old LCD monitors are due to bad caps in the power supply.
Learn more about it here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Please post back what you find so we cab help you further.
Jun 14, 2010 | Lenovo L171 17" LCD Monitor
The monitor is only 2 years old. less then 50
If you left it plugged into the outlet, the power supply is still running 24/7 even you never trun it on! Look inside for bad caps first, see example of failed SAMSUNG monitors: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | Samsung SyncMaster 932GW LCD Monitor
Envision Monitor 22", when plug in the power core, the Green power light would blink repeatedly non stop. Screen would show nothing just a blank screen... it a one year old monitor, and was working fine...
Hi, when connected to a portable you sometime must hold function key then press F5 or F6 to switch between the portable screen and the aux monitor, have you tried the monitor with another computer. If this does not work, it might require internal repairs...
Aug 13, 2009 | Computers & Internet
CPU On Monitor Dead
The monitor, since it is under warranty is best to be examined by an authorized personnel or replaced. As for your laptop, I dont suppose it has a problem. Only that it should have been configured to send display to the external source once plugged.
There are 3 options
  • Native + External
  • Native alone
  • External alone
Your laptop is configured for the 3rd option. You can change this by getting into display properties and under your graphics card configuration. Please do comment if you need further assistance
Jul 25, 2009 | Westinghouse L2046NV Monitor
15" HP Pav. monitor turns on for a second but immed blacks out
Pls ask your dealer about the warranty..It depends as per the market.. If the light is comming then replace the AD card other wise The problem with the inverter card.. replace ...
Jul 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
No plug in play... don't think their dead... do I need drives first?
no country stated or if not usa what is your line power?(volts AC)
your PSU is inside monitor not outside, so uses a simple line power cord. (just wires)
12 year old monitors, found, (dead)
page one of your user guide is clear, read it yet?
seems not.,
Auto-ranging, 90 to 265 VAC
1280 x 1024 @ 60 Hz, 75 Hz (never higher) resolution settings.
those are very old monitors.. worth like $10 used.
if the power lamp shows wrong, the monitor is dead.
right button is power to the right of it is a power led that must glow.
the old monitors had CCFL backlamps before year 2010.
those are back lamps, that fail fast. 20k hours, fast. (short)
first is the power switch
2nd is a working PC with at least sync signals on 2 pins
Horz/vertical.
then the OSD screens work of not the monitor IS DEAD.
inside this OLD monitor is sleep time, turn if off with OSD menu's its nothing but trouble.
some have an OSD lock, so hold the menu key for 10 seconds
and it unlocks. button 2 from left is MENU.
see page 4-10
the guide is here. not too good , poor diagnosis sections
http://h10032.www1.hp.com/ctg/Manual/c00276671
specs.
https://support.hp.com/us-en/product/hp-l1940-lcd-flat-panel-monitor/427303/document/c00278650#AbT3
testing
power it on, LED power , glows.
with a PC working, say running any BIOS screen only....
or running, windows, in low resolution mode 1280 x 1024
if wise set the pc up to that first. not second.
then plug in the vga cable so the MOnitor only sees that signal above. (if you do above wrong, monitor shows OUT OF RANGE on the screen)
at mon.
PUSH the OSD button, menu, if OSD is dead the montor is dead.
OSD= on screen display., (yes the LDC has brain inside)
then take a flash light . point it at screen
see data now, if yes, in the beam is data the back lamp is dead
as are most 12 years old montors now.
see those 4 cream colored connectors bottom of this PCB
those are the high voltage CCFL lamps.
2 lamps 4 ends. the lamps are bad or the board 500 to 1000vdc
power supply is dead.
Sep 20, 2017 | HP L1940 19" LCD Monitor
Monitor not getting info from computer
Does the computer beep when it starts? Does the monitor work on another pc? Possible culprits with these symptoms are the power supply and video card.
Feb 16, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Computers & Internet Logo
56 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
