Question about Honeywell Programmable Thermostat Heater
Asap help I need to know how to get back my temperature back to 72 degrees i do not understant celsius and ferenheit
    Problem Solver:
  • 30 Answers
If you still ahve the manual it should tell you how to get a reset back to factory defaults. you can go from there. if nothing else, unhook the stat, pull the batterys and let it sit a while. it should forget everything. if you tell us the stat model we might be able to better help
saskcat :)
Posted on Feb 04, 2008
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
How to change F to C degrees
for fast conversion use this table:
http://www.rapidtables.com/convert/temperature/fahrenheit-to-celsius.htm
The temperature T in degrees Celsius (°C) is equal to the temperature T in degrees Fahrenheit (°F) minus 32, times 5/9:
T(°C) = (T(°F) - 32) × 5/9
or
T(°C) = (T(°F) - 32) / (9/5)
or
T(°C) = (T(°F) - 32) / 1.8
Example Convert 68 degrees Fahrenheit to degrees Celsius:
T(°C) = (68°F - 32) × 5/9 = 20 °C
Other webpages about conversion:
Fahrenheit to celsius conversion
http://www.wbuf.noaa.gov/tempfc.htm
Conversion of Temperature
Sep 23, 2015 | Refrigerators
Convert celsius to fahrenheit
72 degrees F is about 22.2 degrees C.
Apr 08, 2014 | Office Equipment & Supplies
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Need 2 know how 2 take temp of Lenk soldering gun model 2000.not sure if its getting 2 correct temp.whats temp supposed 2 be,in ferenheit?i have a Etex digital multimeter.really dont know how 2 use it...
It needs to be at least 600 degrees F and should reach 800 or so. 60/40 solder melts around 600, but flows better at about 700 degrees. Most soldering guns require a on-off-on--- sequence to keep the tip at proper temperature. If your gun doesn't seem to be heating, try tightening the tip nuts. Hope this helps!
Oct 27, 2010 | RTO Wall Lenk Corp. LG2000K Soldering Gun...
I want to use two independent Sub procedures: One to convert a temperature from Farenheit to Celsuis, and the other to convert a temperature from Celsuis to Farenheit
Save this as a vbscript (filename.vbs) and modify the language as needed. Should be pretty self explanatory let me know if that works.
Sub ConvertTemp()
temp = InputBox("Please enter the temperature in degrees F.", 1)
MsgBox "The temperature is " & Celsius(temp) & " degrees C."
End Sub
Function Celsius(fDegrees)
Celsius = (fDegrees - 32) * 5 / 9
End Function
Function Fahrenheit(cDegrees)
Fahrenehit = (cDegrees + 32) * 9/ 5
End Function
Apr 05, 2010 | Computers & Internet
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Heating & Cooling Logo
93 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
