Question about Acer Extensa EX4420-5239 Notebook
Lose all battery power within minutes when not plugged in
    Sniper:
  • 65 Answers
Laptop batteries typically need to be replaced every couple of years or so.
Much like cellphones, if you overcharge them then you can ultimately kill cells and keep if from holding any juice.
Good way to keep this from happening in the future is by simply monitoring the amount of charge your battery has while its docked at an outlet.
IF it has a full charge simply take it out and use it on ac power and reserve the battery life for when you need to be mobile.
A new battery can be found either on ebay or directly through the manufacturer. Steer clear from off-brand replacements as I have typically seen a high failure rate.
Hope this helps.
Posted on Dec 11, 2009
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
ES65 restore firmware
Perhaps you still remember the add from IBM. Where the son says, or we put in the power plug!!! There are more errors with portable equipment caused by empty batteries than all other causes together.
Please remove the battery and charge the battery, before placing it back. And even when the charger indicates the battery is full, it is no 100 % guaranty it is. Even almost new batteries, can lose capacity within minutes. Those are defect and most of the time not to recover.
Be aware, to change firmware, if it should be available, you need a working camera. And a fully charged battery, because if during the update the battery runs out of power, your camera won't work again, without an intervention of the repair shop.
Make it a habit to charge the batterie at least every 3 months, even if you don't use the camera for a longer period.
Jan 03, 2014 | Samsung ES65 Digital Camera
While driving jeep loses elect. to engine. still has fuel pressure. after a few minutes it will strat back up.
Check all fuse box connections, battery terminals and leads. Also check age of battery. If it has too much silt in the bottom of it (corrosion) then it may be shorting within.
Nov 13, 2012 | 2000 Jeep Cherokee
I have a problem with my 2003 Yukon losing power and intermittent power to the radio. While driving it will just start decelerating and a light saying reduced power come on. It also hesitates to start but...
Check all fuses in your power box. Sounds like could be electrical short. Check connections and grounds to alternator and starter and battery. Also check coils, plugs etc.
Once resolved, try a can of SeaFoam from Canadian tire $12.00..put half in a full tank of gas and the other half in your oil. Do this when the engine is warm, not hot. Let it sit for 30 minutes then take it for a 10 minute drive and see the difference. Save hundreds in injector flushing. This should alleviate the hard starts.cheers.
Nov 01, 2017 | 2003 GMC Yukon XL
The TV turns on and shows a picture that you can watch and within 10 minutes the TV loses its picture, however, the light is still green. If you turn the TV off you can get the picture to come back after...
The issue here could be a capacitor within the power circuit. Also could be a power transistor that is faulty. On the easy part it could be a matter of reprogramming the unit but I doubt it.
Dec 18, 2017 | Hitachi 42HDT52 42 in. Plasma HDTV
AFTER ALL NIGHT CHARGE BLUETOOTH DEVICE WILL LOSE BATTERY POWER within 15 minutes
hi
the issue here might be that the battery of the bluetooth device might have gone bad and just need repacement ofcourse that is not until after you have ensured that the device was week pluged in to charge..
try charging al over again ensuring its well plugged in and the power in the outlet you are using..
then try replacing the battery...
Feb 03, 2011 | Motorola Cell Phones
I will drive for about a mile with full power with little power lose.then all of a sudden,ill have extreme power loss . within 1quarter mile ill lose all power.something drains the batteries
Batteries do not provide a linear output during usage, but having it die out within a mile or so tells me that one of the battery cells is becoming weaker than the rest. If you're a handyman, you can save yourself a ton of money by replacing only the batteries (try interstate batteries) instead of going to the scooter store and purchasing the batteries and case.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Acer Aspire One PC Notebook- Mini 1GB, WXP
This sounds like the laptop is faulty if within minutes the laptop is totally drained of power from a so-called full charge.
Because the laptop is new then I recommend that you send or take the laptop back for repair or replacement as it's still covered by the manufacturers warranty.
Regards.
Jul 22, 2010 | Acer Aspire One PC Notebook
Model rv-b99 loses presets and does not power off
whenever I run into a memory issue with a portible unit that uses a battery backup I have found battery corrotion on the battery cointacts! also remove the main power source the batteries the wall plug and let it set for several minutes and hit the power switch a few times then retry everything again
Larry(techman)
May 14, 2010 | JVC RV-B99GY Cassette Boombox
Sony DSC-S70, battery not charging to a full charge
That battery is not good.if the battery have warranty please give back and get new one. after that the problem continues, The charging control ic of the camera may be damaged
Sep 21, 2009 | Sony Cyber-Shot DSC-S70 Digital Camera
Acer Extensa EX4420-5239 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
