Question about Acer Aspire One AOA150-1570 Notebook PC
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I did in the past)...it goes into sleep mode and always came back on when pressing a key. This time I had to turn it on. A Blue screen, safe mode, etc came on. I went through allof those steps. Then after shutting down and restarting it would not come up to a blue screen anymore and directly stays black. But I know it is electrically...on. Light is green.
    Sergeant:
  • 244 Answers
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Posted on Dec 12, 2009
Hp probook wont boot
please select boot device from bios
Sep 16, 2013 | Computers & Internet
Acer aspire 6930 6941 won't boot
won't get the check disc option until it boots up and from your description is is a hard drive problem
take it in for a proper diagnosis
Apr 25, 2017 | Computers & Internet
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Toshiba Tecra M5 Boot Problems
man you push alt+ Ctrl +p so you can get it the Bios specially where has been saw it the flash cursor you will see now BIOS normally
Jun 30, 2012 | Toshiba Computers & Internet
Asus eee pc turns on, screen goes blank
If you see the system screen and the cursor, the monitor is fine. You likely either have had your operating system corrupted (I dont know if your EEE PC has Windows 7 or a Linux distribution) or it's possible your hard drive died....but i would try the OS first.
NOTE....do you have a backup of the data??? because reinstalling your operating system will format and erase your data. So if you dont have a backup, you may want to take out the hard drive and plug it into another machine and see if you can make a backup copy of the data first
After that, you choose to boot from your Operating System Disk (Windows 7 disk) follow the prompts to format and reinstall your Windows.
May 31, 2012 | ASUS Eee 900 Netbook
My toshiba laptop will now only turn on to a black screen and a white flashing cursor. I cannot put it in safemode. I cannot put it in boot menu. It goes straight to black screen with white cursor.
it sounds as though its not seeing the hard drive. Power up and press delete to get into the bios. The hard drive should be seen in the first or second screen. If its not there then you will need a new one and a new installation of windows.
Aug 29, 2011 | Toshiba Satellite L645DS4037 Notebook PC
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Turn on the netbook the first screen offers f2 or f12 options then it goes black screen with a cursor at the top. at this point nothing works
It asking you if you want to go into the bios (setup) or to choose a boot option.
Choose the boot option and select hard disk drive 0. If it doesn't boot, you're hard disk has probably failed.
You can test by inserting a bootable diagnostic (UBCD4Windows) disk, or re-installing the operating system.
This will underscore whether you HDD as failed just wiped.
Dec 20, 2010 | Computers & Internet
I am trying to replace the hard drive in my compaq evo n1020v. The problem I am having is that when I turn on the computer, it doesn't seem to be booting from the windows CD. It just sits there and does...
you need to set the jumper setting from your Hard Drive as Master Drive and the CD/DVD player is Slave then go to Bios settings then set 1st boot CD/DVD to boot the windows installer..good luck and have a nice day..
Jun 27, 2009 | Computers & Internet
Toshiba Satellite A215-S7437 will not boot up...
Take out the hard drive completely and then see if you hear the clicking noise, if you do then that means the hard drive is bad. Also if it goes right to another message and you don't see the blinking cursor then that also verifies that the hard drive was bad and causing the system to hang.
Jun 12, 2009 | Toshiba Satellite A215-S4747 Notebook
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
234 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
