Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
My digital camera wont work and it keep saying DEW. what does that mean? it is a sharp vl-z5 digital camera
  • 48 Answers
Never let your video camera get dew which is dust and debrss fro cheap cassets iner dew so be careful keep it clean.
Noe batteries you need top of the line with a seperate charger making it a non problematic future.
Posted on Feb 08, 2010
I HAVE A VIEWCAM VL-Z7, I STARTED TO CHARGE MY BATERRY TO THIS JUNKY UNIVERSAL CHARGER AND FOR SOME REASON IT TURNED ON BUT 1 MINUTE LATER IT TURNED OFF AND NEVER TURNED ON AGAIN
Posted on Dec 26, 2009
SOURCE:
Whot does it mean when dew on screen and turns off just after
"Dew" means there is condensation (moisture) in the camera. The camera may refuse to operate until it is thoroughly dried out.
Nov 29, 2010 | E.Digital Sharp VL-Z5E Digital Viewcam...
My video camera keeps saying dew all the time
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Nov 06, 2010 | Sharp VL-Z5 Mini DV Digital Camcorder
Hi When I switch on cam, I am getting the text DEW
Sounds like condensation. This can cause the tape to stick and snarl, so the camera probably won't lace up until it drys out. If you leave it in a warm dry place for a few days it should clear up.
Nov 04, 2010 | Sharp VL-Z5 Mini DV Digital Camcorder
The camera wont stay on for more than 10 seconds, flashing message: DEW
Obviously excessive humidity inside the camcorder.
Follow whatever described in the manual.Or if you had already lost it,just let your camcorder in dry place for a couple of days.This should fix your problem.
Aug 20, 2010 | Sharp VL-Z5 Mini DV Digital Camcorder
WHEN I TURN ON THE CAMCORDER IT SAYS DEW
Hi, dew mean its the humidity sensor is on
thats lock all operation/ you can try an air dryer
:/open the loading tray if you can and blow at medium hot ,some hot air in slot for mechanism for few minutes avoid to be to close off the pastic cassing
and leave it rest for a few minutes and try it...
if wont work that is the dew sensor it self defect
hope that will help
Mar 29, 2010 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder shows dew all the time
http://ataplow.googlepages.com/sharp-dew-problem just click this link read the instructions carefully and follow them properly to resolve this problem. thanks.
Jan 27, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Unable to start the camera
I had the same problem on a Sharp VL-Z3U
This was what worked for it & yours may very well be the same thing:
The solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Dew lamp lights up and camera shuts down
Nov 17, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
452 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
