Question about Memorex MVD2042 DVD Player
Memorex 6 Hi Fi Stereo DVD player
Movie shows on a split screen, unable to change so that movie is shown on full screen.
  • Anonymous Feb 15, 2008
    the screen is split verticly with an exclaimation point in a triangle with ' PSCAN ' under it.
Just turn off the progeressive scan on the back of your dvd player.
Posted on Feb 10, 2008
How can I obtain a picture that covers the full screen width?
There are settings accessed through the TV remote that should allow you to adjust the screen size. Sometimes movie rentals are shown at widescreen (black at top and bottom of screen) due to how the actual movie was made to be viewed by the viewing audience.
Sep 19, 2014 | Televison & Video
Dvd player ford expedition
Check the connections from the player and the connections to the screen. Does it discolor when played in full screen?
May 26, 2014 | Ford Cars & Trucks
It is not DVD problem but I think you have to change the display screen which might be damage. You have to go to reputable service centre and change screen to enjoy a movie while travelling.
Prime Choice Auto Parts Coupon Code
May 26, 2014 | 2010 Ford Expedition
Tv full screen picture
thats called letterbox mode it all depends on how the movie or show was filmed years ago it was called cinemascope you can change it manually via your tv remote
May 04, 2014 | Televison & Video
How to insert video in the PowerPoint 2003?
Insert a movie and play it automatically
In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
  • On the Insert menu, point to Movies and Sounds, and then click Movie from File.
  • Click the video you want to use and then click OK.
  • Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
  • After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
    I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
  • You should now have a small rectangle sitting on your slide.
  • Insert a movie using a file on your computer or in another location, such as a server.
  • The movie appears as a still frame on your slide.
  • The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
    Play the movie full screen
  • Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
  • The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
  • If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie
If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it.
3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear.
You have added an On Click effect. The animation effect you added is the one with the Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this:
6. You are done. Test this to make sure it works by starting the slide show.
(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce: How to insert a Movie (or video) into PowerPoint 2003?
Jul 06, 2010 | Microsoft Office Professional 2007 Full...
Main screen has no picture
go to you`r pics and change wich pic you want.
Jun 27, 2009 | Durabrand DUR7 Portable DVD Player
Movies projected from laptop
This is a laptop issue. Not a problem with the projector.
Nov 07, 2008 | Epson Office Equipment & Supplies
Download a movie from itunes
with your iphone connected to your computer/itunes running and movie downloaded.. Click on the icon for your iphone that shows on the left of itunes you will be given a screen with several tabs along the top one of them is video click that and you will be shown 3 sections for rented movies, TV shows and Movies.. your download should be here for you to select for sync to your phone
Aug 03, 2008 | Apple iPhone 3G
Memorex MVD2042 DVD Player Logo
142 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
