Question about Sharp AL-1641CS Laser Digital Copier
Machine started making a loud clicking sound and wont copy
I was coping and the machine started making a loud clicking sound coming from the the paper feeder area, the p flashes, and wont copy
  • 622 Answers
Fuser roller gear is cracked... or a spring holding the bypass is loose
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 11, 2009
Canon imageclass d340 making a loud clicking sound
It sounds like you may have sheared a gear tooth off the roller drive or the traversing mechanism. If you are getting copies just leave it alone.
Oct 12, 2016 | Canon imageCLASS D340 All-In-One Laser...
Why will printer not pull paper and makes clicking sound?
Did you have a paper jam before the noise started, if so there may still be some paper stuck in there or you make have a brocken tooth on one of your drive gears.
Jul 16, 2014 | HP Photosmart C3100
We have a MFC8460N, when we go to make copies there is a loud clicking noise & it says 'paper jam' & will not make copies
Hi
The clicking sound comes from the paper tray. The problem is that the paper gets jammed when it feeds the paper and it will sound clicking because the printer cannot pick up the paper at the tray.
What you will do is to put bond paper into a tray but the paper head should not be so tighten. Just put the bond paper with the top paper in upward position.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 02, 2011 | Brother MFC-8460N All-In-One Printer
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Loud clicking noise
we need to perform a reset, it will take the pritner to the factory settings and this may help you,
the process of reset goes like.
unplug the power cable from the pritner >
then press and hold down the # key and 6 key >
while pressing and holding these keys plug in the power cable back into the printer and wait for 20 secs and then release the buttons..
after this the printer will re-initialize and this might take few minutes.. so wait untill it finishes and follow the onscreeen instruction as well.(if any)
Nov 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Coping
this sounds like you have ink on the paper look inside and clean the paper feed rollers with denatured alcahol found at the local hardware store
Jul 05, 2008 | Brother MFC-465CN InkJet Printer
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Brother multifunction inkjet DCP770CW. How can you adjust the copy function to cope with pages of pencilled notes that come out too feint. Mike Cornwell
no way. the paper feeder of machine recognices the paper edges. there is no way to compute the exactly positon for different papers.
May 01, 2008 | Office Equipment & Supplies
Sharp AL-1641CS Laser Digital Copier Logo
127 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
