Question about Altec Lansing ADA 885 Computer Speakers
Compatability with TV
Can I use my Altec ADA 885 speaker system with input from my TV? I want to be able to switch back and forth between the TV and computer through a selector switch. Any reason why I can't do this?
Tim
    Brigadier General:
  • 6,966 Answers
Yes but you will not enjoy all the features of the Altec ADA 885 speaker system and if the TV's features will allow you.
Most TV's do not have audio out and if ever they do, chances are that it will only be left/right. Your Altec ADA 885 speaker system is capable of getting multiple inputs other than just left & right; main, front, surround & S/PDIF.
Hardware wise, the standard audio connector to the audio outputs of your PC are baby phone plugs, while those in the TV are RCA. If ever you will push through, you would need to get hold of a stereo RCA to baby phone cable. Am not sure if the yellow dongle cable that came with your package is long enough.
Additionally, here is a link to the normal installation instructions for an Altec ADA 885 speaker system should you be interested.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Jan 20, 2008
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on...
Throw it away, they are garbage speakers. I ordered one and ended up giving it away as it was so dire. It hissed when turned off, it drove me mad! The part you are missing is the amplifier which is in a small box unit in the right hand front speaker. Power goes into it and the input audio is amplified and goes to the Sub Woofer and the two satellite front speakers.
It will work on a stereo amplifier, but not as it is.
Manual
Using the Speaker System Altec Lansing ADA885 User Guide
Set up
Setup Altec Lansing ADA885 User Guide
Mar 10, 2018 | Altec Lansing Audio Players & Recorders
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
How do you connect the altec lansing ada 890 speakers to a flat panel HD TV
You can use the audio output RCA outputs to connect to the speakers. You need to use a multi- connector to match the input of the Altec. You can get the mating connectors to the headphone to RCA which can be connected to the Audio outputs. Also you can use a network to match the input impedance, use a simple reisitive network.
Dec 09, 2011 | Altec Lansing ADA 890 Computer Speakers
No sound from subwoofer
If your subwoofer does not work on your altec lansing speakers,
more than likely you blew the subwoofer amplifier board.
I have an ADA-885 system and bought it brand new back in
November 2000 and has been flawlessly operating great up
until this past month when my subwoofer went out but my
"satellite" speakers kept working. After disassembling the
subwoofer box I first noticed that the subwoofer amplifier
board is seperate from the rest of the grouped boards for
the dolby and satellite speakers. The subwoofer box is
designed to use the air from the subwoofer to actually
cool the amplifier boards inside the unit, great feature
until your subwoofer goes out, that is when your main
amp will more than likely fail soon after the sub amp
fails, as it uses the air from the subwoofer to keep the
amps cool. I know this might be an older post but
hopefully I can put it in the right category to hopefully
be able to help someone out in the future.
You can test the ohms of the speaker with a multi
tester. It's a dual voice coil speaker, 6 ohms each.
Well my system is broke and needs another
subwoofer amplifier board so if anybody reads
this and has this subwoofer, I need my sub amp
fixed ! or if you have the subwoofer unit maybe
and nothing else to go with it but the subwoofer
lights up, give me a jingle, I'd buy it from you !!
Jul 23, 2011 | Altec Lansing ADA 885 Computer Speakers
Hello, I have an Altes lansing ad-885 system and I have lost the cable that connects it to the pc, Where can I purchase a replacement. Thanks,
Altec Lansing ADA 885 connects with an SPDIF cable. Something like this should do the trick for you:
http://www.amazon.com/Toslink-Digital-SPDIF-Optical-Performance/dp/B001ENJ3ZA
Dec 22, 2010 | Altec Lansing ADA 885 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Bass Problem
you may have a short in the wiring
you can always open up the bass box and look to see if the wiring is a little loose.
if you know how to use soldering you may be able to fix it.
if not you may be able to just tape it in place
Apr 29, 2009 | Altec Lansing ADA 885 Computer Speakers
Can I hook up my ada 885 to my dvd player& my flatscreen tv?
Yes. They are essentially Similar to any other 120 Watt Surround System for Home Entertainment. The Fact is, the only major difference is that the connections are different. On The PC it uses Stereo Standard Outputs. On Your DVD Player, It Will most Likely require an adapter to RCA (red/white -usually- Audio Cables). It just depends on your DVD Player. Have Fun!..... :)
Apr 20, 2009 | Altec Lansing ADA 885 Computer Speakers
How to hook my altec lansing speakers to my TV? and my laptop @ the same time
You can do this through a receiver (like a stereo receiver). Hook the tv up to line 1 and the computer up to line 2, then hook the stereo receiver output to the input of your subwoofer. Then shift the receiver from line 1 to line 2 (as easy as pressing a button on the front of the receiver) to hear either one through your speakers.
Nov 26, 2008 | Altec Lansing ADA 885 Computer Speakers
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
May 11, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
442 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
