Question about Vizio VW42LF 42 in. LCD HDTV
No picture w/sound screen blk - Vizio VW42LF 42 in. LCD HDTV
  • jazzplayer Dec 28, 2009
    if noticed my screen only blacks when hdmi is bieng used
    i have apple tv media box. when i use component connectors, no problem. could th e cable be bad ?
  • Vizio Master
  • 3,866 Answers
1. Bad back-light
2. Bad inverter
if you got sound ether one of two of these are fact with your TV. Repair is simple for any qualified tech and it wold be around $100 bucks flat to fix.
Now you may want to check all your sources like video/hdmi/coaxe and make sure that this is not isolated with a cable box,ps3 or ame console or something weird. Try also unplugging the TV and plug it back in you just never know.
please do click the accept button for your answer today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Dec 11, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Dec 28, 2009
    The cable could very well be bad, that would be what I would try, Thanks and good luck to you have a wonderful new year!
Sharp lcd tv. Grn lite flashing, reset by unplug, vol + ch - , plug in. Tv came back on, after few mins screen goes blk, have sound. turn off and on picture back for few minutes, goes blk, snd ok.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 07, 2017 | Sharp Televison & Video
I have an RCA HDTV 52 in 2005 model that makes a humming noise picture color starts jumping in and out from color to blk and white then picture totally goes blk, then after a few minutes will come bk on....
with the symptoms id start looking in the High Voltage area for a Multiplier block failing or possible fly back transformer and i would not continue watching it ti the problem is isolated and repaired as this can further damage and destroy a video processor IC or other parts but id suspect a multiplier block or high voltage tripler is another name for it it is its accesable from the front by removing the speaker panel and be CAREFUL as there is High Voltage present there and you could get a Nasty Zap
Dec 14, 2014 | RCA Televison & Video
Sony flat screen tv- model KDL 40S5100
if you don't have the remote, you can use the channel and volume controls navigate you thru the menu. if all of your settings are to the left. then yes you will have no color and a dim picture, if any
Dec 11, 2017 | Televison & Video
32me402v Magnzvox
If the set is still under warranty period, use it. The main power supply regulator board had the fault.
Jun 28, 2013 | Magnavox NEW 32ME402V BLK 32" LED TV 1080P...
No picture/completely blk screen - just sound
You have a bad lcd you will have to get it replaced. I have repaired alot of phones with that issue.
"Please leave me a testimonial or feedback if this helped you, thanks"
Oct 27, 2010 | Cell Phones
My tv has too much red in picture
Adjust the color control down, first turn color off see if you have a Black and white Picture if not you need to adjust screen drive controls to each tube untill you have Blk and WHT picture then turn color back on.
Mar 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
No picture Screen black
Hi, you need to get your TV kit replaced... Please reply with the model number of your TV if you repairing it by your own.
Jul 20, 2009 | Protron Televison & Video
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Top part of screen is black
A "black box" sounds like the close caption is turned on. Go into the menu and make sure it is off. If it is not close caption, you have a bad problem. If the top half of the picture is missing, this sound like a panel problem. The panel will need to be replaced. Panels are not cost effective to fix. Buy a new tv.
Nov 15, 2008 | iLO V27DMBX Television
Photo-copied Blk & White pictures come out with a pink tinge instead of blk & white.
haven't come across this problem myself, but renew all the ink cartridges, using Epson genuine only and no refills
Feb 09, 2008 | Epson Stylus RX500 All-In-One InkJet...
Vizio VW42LF 42 in. LCD HDTV Logo
63 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
