Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 55hx70 projection tv problem
It powers off on its own....red power light on the bottom right blinks on and off...
any idea what i can do to fix it or how much it'd cost to have fixed? thanks for any help! brian
  • inf1nite Jan 20, 2008
    ummm...this was the first time turning it on all morning and it lasted a minute and a half or so....started blinking with like 1 second intervals...and its still blinking its been another minute or 2....while the tv was on though there were lines all across the tv moving up and down and every which way as well....i hope that helps? thanks, brian
    Wow thanks, I will go ahead and purchase that then. I appreciate that! I just got this tv from a friend that said it was on its way to its funeral! So i figured maybe I could have someone fix it or do it myself. Do you believe it's possible to do it myself? Thanks again for the help though, Really do appreciate it!
  • Toshiba Master
  • 8,617 Answers
How many times does the light blink? It should blink a number of times, pause then blink the same amount then pause. Try to count the blinks then let me know. Also how long does it run before shutting down if any?
Posted on Jan 20, 2008
  • Sonny Berry
    Sonny Berry Jan 20, 2008
    It sounds like it might be video or tuner related. You will probaly need a service manual to figure it out. I am enclosing a link where you can purchase one for 10.99 and they will provide free support to help you diagnose the problem. They will also email the manual to you if you return to the site and request that they email it to you. Hers the link if you want the service manual for your set.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    as long as you careful, get the manual and get the support you should be fine rebuilding the set. You just have to be cautious around the voltages within the set. Proceed cool and calm and you should be fine.
Red power lights blinks and tv will cut off. sometimes after you unplug it it will come on after about 10 min. now it will not come on unless you unplug it and then it will work about 5 min and cut off...
depending on the age of your tv, this appears to be a common issue. Blame it on the ballast board. your ballast might not be able to provide the lamp w/ enough voltage to keep the image on for longer period of times. or it could simply be that you need a new tv lamp.
Apr 13, 2010 | Toshiba 55HX70 55" Rear Projection...
RED POWER LIGHT BLINKS
Red power light blinks and tv will not turn on it is a 65h81 Toshiba HD
Jun 19, 2009 | Toshiba 65H81 65" Rear Projection...
Click when plugged in and steady blinking red light.
hello it sounds like it could be just a dry joint on the video section of the tv good luck
shaun
May 27, 2009 | Toshiba 43HX71 43" Rear Projection...
Toshiba 57H81 57" TV Power
I have a toshiba 55hx70 same problem,repair guy just left said it was the power supply and wasnt worth fixing 350 to 400 dollars The tv is 9 years old and they wouldnt even take it to shop. Its been a great tv firs thing to go wrong.. Wo nder if I could replace it myself???
Dec 22, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Model 55X70 Toshiba Projection tv
dont know about warranties but horizontal lines means your horizontal frequency which runs about everything has drifted off sync and if too high or low it will activate shut down circuits in high voltage and power suppy, even causing HOT transistor to short. good luck and call a tech.
Sep 01, 2007 | Toshiba 55HX70 55" Rear Projection...
Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 28, 2007 | Toshiba 55HX70 55" Rear Projection...
55HX70
needs convergence ics period
Nov 24, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
