Question about Bosch Air Tools & Compressors
CH TLX102 Air Drill Air Leak
I opened this gun as the shaft was not tight enough. Replaced it with one from an identical gun and put it all back together, was simple enough. Now both guns have the identical issue, air leaks from the trigger area. There are no seals that I can see and am wondering what the problem is?
  • spirosm73 Dec 12, 2009
    So you were all wrong with your advice which means you didnt check info on the model in question. There are no steel ball nor is there an o ring. The problem was the gasket on the back cover of the gun which directs the air. Problem solved on my own. Thanks
    President:
  • 2,976 Answers
THe drills normally have one of two types of mechanisms at the trigger. An "O" ring or a small steel ball. Since you didn't see any rings or other seals, you need the ball. It is about 1/8" diameter and it is held in place by a spring.
Posted on Dec 11, 2009
The gun had a slight air leak at the trigger. The repair shop put in an o-ring kit. Works great on their shop compressor. Plugged it into 2 different portable compressors and air leaks continuously from...
Roger, what PSI are you running on your portable compressors? Sometimes these guns will not operate properly if there is not enough air pressure. I have seen some guns that if the air pressure is too low that they will not seal up properly and act as if there is a leak. If you can adjust your portables make sure that your setting is at least what the minimum setting for your gun calls for and then adjust upwards if you need it to drive deeper. Hope this helps.
Jul 22, 2014 | Hitachi NR83A2 Framing Nailer Full Head...
I have a Hitachi coil nailer model # NV 83A and air leaks out the exaust when you put aior to it. I have replaced the exaust valve, piston bumper, piston o-ring, feeder shaft o-ring, and plunger o-rings,...
I dont recall that there are any orings in the head area. Large leak from head area is caused by cylinder not retracting and seating against headvave. Small leak is usually gaskets between headvalve or cracked tube above headvale or rubber tube seal not seating against body of the gun. Test cylinder movement. Remove the head and push down cylinder, the cylinder should retract. If the cylinder is already down, pull it up. If the cylinder is very hard to pull up, most likely orings too tight or body of gun is warped. If the cylinder moves up with just little force, reinstall head and retest. If small leak, remove head and remove headvalve and look very closely for cracks in the head and tubes.
Sep 24, 2011 | Hitachi Tools & Hardware - Others
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
My nail gun miss fires. seems there is not enough tension pushing the nails forward
Could be that the driver is not returning to top of the cylinder. Easy test, when the gun miss fires, remove air line, with thin metal, insert thru nose and push driver up. Retest gun. If driver was down a bit then nails will not feed. Remove head and check that driver oring is making good seal, lubed, and is not too tight or bent. Also check that lower bumper is not cracked or missing pieces. Replace parts as needed. If driver was all the way up, clean rails and pusher assembly with wd40 and follow with good cleaning with air. If pusher and rails working properly, must be problem with bad batch of nails, slightly thicker or wider head not allowing nail to easily slide. Open nose latch and check that nails slide thru easily.
May 10, 2011 | Porter Cable 16 - Gauge Finish Brad Nailer...
Replaced the mandrel on my Craftsman Model 917.273640 following the schematics on Parts Direct. When you put the pulley on the splines, there is too much play. It doesn't appear to tighten down as far as...
Yes a second washer would be acceptable as long as the splines on the shaft are at or slightly above the top of the pulley but it shouldn't be needed as long as the nut is torqued tight enough. Make sure the pulley is in good shape and the nut gets torqued down properly or the splines will tear up. There should have been a set of instructions with the new mandrel that gave the torque spec. Normally I just use a 1/2 inch drive craftsman air impact gun set to full power with about 100# air pressure. It is a rather large lock nut so it takes a lot of torque. Hope this helps. Please vote yes, thank you.
Nov 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The keyless chuck on my "PSB 5000 RE" electric drill has jamed up and cannot be used. Can it be replaced or is the whole electric drill a throw-away?
chucks are screwed to the drill by a left hand theaded screw. try to get the jaws open enough to access screw then replace with new keyed jacobs chuck. they are brill.
Aug 12, 2010 | Bosch Garden
Not firing leaking air out top
this will be one of 2 problems either the four bolts that connect the back plate are not tight enough (if the air is coming out of the seal) or if you open the back plate and look in the back you will see a sort of plastic diaphram in this is a spring that will have snapped i know because im online now looking for a spring for 2 of mine at the moment
Jul 03, 2009 | Stanley Bostitch N88rh Framing Nailer...
Iwata w400 air leak behind trigger problem
Have you traced the exact spot of the leak?
I will assume you have not. the reason it's important is because if there is a crack in the o-ring seat there is nothing you can do. So trace the leak. Try a small amount of auto air conditioner leak detector or something similar even ink from an ink pen will work. Place it in the air inlet, hook up your air line and trigger your gun for a 10 to 15 seconds. disassemble your trigger and see if you can locate the offending spot. Though this method has worked for me in the past, it's not something I would normally recommend. However the gun you have is to expensive to just write off.
The alternative is to contact Iwata and seek help.
Good luck.
Jun 23, 2009 | RTO Iwata 1.4 W-400 Gravity Feed Spray...
Will not pull piston back after shooting a nail
first thing i would do is to make sure this gun needs oil .most of your newer guns don't take oil.and if this is true with your gun you will need to rinse all of it out, hear is a place you can get a schematic. http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/BN200
Mar 26, 2009 | Porter Cable-Cable BN200B 5/8-inch to...
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Mar 11, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
149 people viewed this question
Top Bosch Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Jim Goldsmith
Jim Goldsmith
Are you a Bosch Air Tool and Compressor Expert? Answer questions, earn points and help others
