Question about Kodak EasyShare DX7630 Digital Camera
High temp amd power spikes
I frequently get a "High Temp" warning and the camera shuts off. It will also mysteriously power on and then off even when the power control is in the off position. Any ideas or is it time to junk it?
    Genius:
  • Kodak Master
  • 1,099 Answers
Time to trade up. Due to spare part shortage this model is no longer repaired.
Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 11, 2009
  • finesilver Jan 01, 2011
    this worked for me: just hit the bottom hard with your palm and the top and sides, not the front or back. After 3 hits, the date screen came back on and it was fixed. This was after the other two solutions I found on this site failed, namely pushing the shutter down before the message comes on or blowing into the camera slot with the memory card removed.
Fan motor won't turn off even with car off
Fan relay or temp sensor is bad.
Jan 03, 2018 | Cars & Trucks
Major Coolant leak
So you had it at several repair shop that can't find anything
or don't believ your loosing coolant
Sorry I can't guess I would need the car to check & test
Some major issue like a Head Gasket ??
Nov 29, 2012 | Cars & Trucks
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
Frequent alarms "Control power loss" Often
Control power loss is often caused by high airend temp or a faulty High Air Temp. switch(HAT Switch). I suspect the HAT switch is bad and opening prematurely because the att. temp. probe located next to the Hat switch is set to give a temp alarm and shut down the compressor at 228 degrees.The hat switch is located in the end of the airend and should have a 1/2 " flex conduit attached to it. When this switch opens it cuts control power. Thus the controller issues a control power loss. This switch is set to open at 245 degrees. If faulty it may open at 150, 180, 200. Anything but what it is set at. You can check this switch with a meter. When the unit trips simply test for 110 volts at the switch or in the control panel if familiar with wiring . please be very careful while in any electrical panel.. 110 volts in, 110 volts out. NO 110 volts out or on one leg of the switch means its bad and should be replaced.After it cools for a while the compressor will run again.
Jun 08, 2011 | Ingersoll Air Tools & Compressors
High temp 20-29 F Frequent high temp alarms
check condensor fan if it has one. if not unit may have sprung a leak some where
Apr 10, 2010 | Freezers
2001 dodge stratus engine temperature gauge spikes occasionally
Look for a loose connection to the temperature sender unit on the motor.
If all connections OK, you may need a new temp sender unit.
Jul 28, 2009 | 2002 Dodge Stratus
Computer is turning off frequently,automaticaly.
IF it is windows it is something to do with power management go to control panel and in power management disable the restart option and diable the hibernation mode too and in BIOS reset to default
Jul 02, 2009 | Computers & Internet
When I turn the camera on the following message appears- high camera temperature, camera will shut off. The camera is a Kodak easyShare Z710
Have Kodak Easyshare V1253 with same, "high temp.," error then shutdown. Kodak batt. showed 25% charged. Charged batt 100% & temp. error went away. Batt. internal shows camera if batt. too hot. Try new batt.
Sep 12, 2008 | Cameras
High temp warning
2 BLINKS: Temperature
Apr 05, 2008 | Sony KDS-R50XBR1 50" HDTV
Kodak EasyShare DX7630 Digital Camera Logo
142 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
