Question about Husqvarna Viking 1
Threading a Viking Husqvarna 1100
I just bought this used machine. I have the owner's manual but it isn't very clear on exactly how to thread a Viking Husqvarna 1100. The thread feels too tight to me and keeps breaking. I feel like it's because I don't have it threaded properly rather than a tension adjustment. Also, when I tried to fill the bobbin, it only filled about halfway but this could be because of the machine not being threaded correctly.
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
  • 4 Answers
SOURCE: My threading is too loose?
Thank you - fixed it completely... though you have to take the bobbin case out completely to access that screw. - Remove the 2 screws holding the metal plate with a nickel and remove the plastic piece over the bobbin case - there is a small metal lever on the lower left side that needs to be pressed down. You can then remove the bobbin case. There are 3 screws - the center one is the tension adjustment. It was painted green on my machine.  It appears that it is not a regular setting change, but a bad adjustment from the factory. So if you don't feel comfortable doing all that returning the machine for another will likely fix the issue.
Posted on Mar 26, 2009
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
  • 371 Answers
SOURCE: The bobbin thread on my Viking Designer 1 is too tight
In most cases, this is caused by loose threads and fluff being in the upper tension unit rather than a problem with the bobbin. There is a screw on the bobbin case that losens and tightens the resistence. However, it can easily come out and then you have a mess.
Try this to check the bobbin thread tension -
Take the bobbin case holder out of the machine. Use a bobbin that is about half full and use standard 50 wt sewing thread.
Take your needle plate (the metal plate over the feed dogs that has markings showing stitch width under the presser foot).
Thread the bobbin thread in the bobbin case, holding the case so that the thread is through the tension spring as though it is in the machine, tied the end of the tread to the needle plate and have it hang below the the bobbin case.
If the needle plate immediately drops to the floor, unwinding the bobbin, the bobbin tension is too loose. If you jiggle the bobbin case slightly up and down and the needle plate moves slightly down, it is just right. If it does not move at all it is too tight. The resistence should be 14g which is the weight of the needle plate.
The upper tension unit, look straight down from the tension unit and you should see some metal disks which the upper thread rides through when threaded. Take your small cleaning brush and brush out any loose threads/fluff there. Look down the left side of the tension unit to make sure there is none hiding.
When you tighten the upper tension unit by pushing the tension buttons on the screen, do you hear the tension disks tightening? If not, it may be the pc board or the tension unit itself that will have to be replaced.
Otherwise, you might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck
Posted on Feb 13, 2010
How do you thread the 425 husqvarna viking machine?
Perhaps this will help (page 9):
Be sure to ALWAYS RAISE the presser foot when threading the top thread!
Viking Freesia 415 User Manual
May 16, 2018 | Husqvarna Sewing Machines
Threading the husqvarna 220 sewing machine
the owner's manual would have a diagram. Otherwise, search for
Make Model threading
Husqvarna Emerald Threading the Machine
machines generally thread in the same manner.
Apr 04, 2017 | Husqvarna Sewing Machines
I need to wind thread the bobbin for a husqvarna viking 500 computer sewing machine
Download your manual here: http://www.pdfsdocuments.com/husqvarna-viking-500-computer-sewing-machine-manual.pdf
Feb 02, 2016 | Husqvarna Sewing Machines
Need to know how to take the cover off of a viking 400 sewing machine?
Screws are either T10 or T20. There are some on the back and some on the bottom. However, would recommend taking it to a Viking Service Tech for repair. Occasionally you can use tweezers and pull thread out if it is not tightly embedded in the sewing head. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website - http://www.husqvarnaviking.com/us
Aug 18, 2014 | Husqvarna Viking 1
How do I thread the Husvarna 910 serger?
Hard to explain here. You will probably need pictures to show you exactly. If you don't have the user manual/guide, it should be available on the husqvarna viking website under 'Machine Updates' (bottom right hand corner of home page). From Machine Updates page, select All machines and scroll down until you find your machine listed. Also most viking dealers are familiar with this machine and should be able to help you thread it if you stop by their store with the machine. You can find a dealer near you by using 'Locate a Dealer' link at the husqvarna viking website
May 31, 2014 | Husqvarna Huskylock Computerized 910
Huskeystar c 20
Check the Viking website to download the owner's manual for free. The manual will have instructions for threading the machine.
At bottom of the page select Machine Updates
Click on All Machines and select the Huskystar C20 machine.
The next page will display a picture of the machine and will have a link to Download the Manual.
Dec 22, 2013 | Husqvarna Sewing Machines
Sewing Machines Logo
541 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
