Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire Model# LTF2140ES0 washer stopped spinning
My machine just stopped spinning. Looks like an electonic issue, but the contorls look fine, can it just be the motor that blew out?
  • dan mccullough Jun 20, 2012
    i have the same issue and the pump is moving the water because there is no standing water in the drum. is this the Motor? the drum moves in the wash cycle umbling the clothes but will not spin the drive the water out of the clothes.
    Scholar:
  • 68 Answers
DOES THE DRUM ROTATE AT ALL? IF SO, IS THERE VISIBLE WATER STILL IN THE MACHINE. IF THE PUMP IS CLOGGED OR JUST BAD, YOUR MACHINE WILL NOT GO INTO SPIN CYCLE TILL THE WATER IS DRAINED FULLY
Posted on Dec 11, 2009
SOURCE:
Frigidaire LTF2140ES0 washer lights come on but doesn't start
Hello friend, thanks for your post!
If your Frigidaire washer, LTF2140ES0, is not starting it could be a possible issue with your control panel or door latch. Is your washer showing you any error codes? Double-check to ensure that the door is closed. If it is secure, reset the power to your washer for roughly ten minutes. You can do this by either unplugging it or flipping your circuit breaker into the off position. If the issue continues, it could either be the door lock assembly or a communication problem with the control board. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. I hope these troubleshooting tips help you in some small way. -Matt
Sep 25, 2014 | Washing Machines
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Washer Froze, Spin Cycle Sounds like Jet Engine
when it goes into a high spin does it sound like a freight train in your house if so your bearings are going bad
Dec 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load washer isn't spinning out
The first thing to check is if the door is locking. Put the unit into spin turn unit on let it go for about a minute then shut it off, try to open the door right after you shut it off if the door opens you need a door switch if not chances are you need a motor control board. Before replacing the board call for service they are expensive if it is a guess. good luck
Dec 26, 2008 | Frigidaire GLTF1670A Front Load Washer
Fridgidaire washer problem
As a front loader it is different than a top loader. It sounds like your pump is dead or there is an issue with the drain hose or how far it sits in the drain. A clog and/or a siphoning condition can lead to this as also how much and what type of soap is used. A suds lock can cause this also. If the machine agitates fine and the timer advances then the motor control unit is fine. Lets see the only other problem I see is an imbalance. I will post a pic so you can see your machine better.
Oct 29, 2008 | Washing Machines
Frigidaire GLTF1670ASO is cycling fast and not spinning
Hi , try to check timer small motor .,also available in appliances store.
Feb 15, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
411 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
