Question about Hampton Bay AC434-NI Ceiling Fan
Can this fan be installed without the light kit? If so, will the upper light work?
    Problem Solver:
  • 8 Answers
The white is neutral. the black wire is for fan. the blue is for the lower light kit. The orange wire is for the four candelabra lights in the upper section.
Posted on Oct 13, 2011
  • 183 Answers
Most newer ceiling fans have 3 wires, a black, white and blue. The blue is for a light kit which is optional in most cases. All other functions should work.
Posted on Dec 11, 2009
Model 53012, how to install without light kit?
Take the bottom cup off. Disconnect the two light wires. Screw light kit off cup. Reinstall cup.
Jul 21, 2015 | Hunter Dryers
Finding a light kit for a casablanca 652T fan
That's an old model so I don't know without seeing a pic for sure. If it has three screws on the bottom plate,you have to use an older Casa. light kit or almost any Bowl light should work. fanman9952@aol.com
Mar 27, 2013 | Dryers
I am installing a light kit to a hunter Original paddle fan. The neutral -white in the fan is marked for a light kit but I cannot figure which is the black or hot wire in the fan
Here is the information given to me by a Hunter rep when I worked at the big box store.
(901) 248-2259 Technical/ Parts
or parts/ technical service (901) 248-2327
As a side note, most fans use the White and Blue wires to supply power to the light kit.
The blue generally attaches to the Black wire when installing light kits, and the
White to White.
Hope this is useful.
Jul 31, 2011 | Heating & Cooling
Trying to connect a ceiling fan light kit. I connected the blue wire from the fan kit to the black wire in the light kit and then connected the white wire from the fan kit to the white wire in the light...
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
May 30, 2010 | Hampton Bay 24002 Ceiling Fan
Fan remote nor lights work.
FIRST CHECK THE WIRE CONNECTIONS IN THE FAN ARE NOT LOOSE ,IF ALL CONNECTIONS ARE GOOD THEN I WOULD SUGGEST YOU REPLACE REMOTE.
Nov 08, 2009 | Dryers
Looking for light kit for ceiling fan
if you can manage doing some mechanical stuff and electrical connection, this can be done, however it is difficult to say what kind of fixture will fit your existing fan, say for example the mounting plate, this will be a little tough job, there are a lot of light kit available in home depot, the only problem is if you can manage to connect this electrically and mechanically.
let me know your model and if you have a remote control base type.. cheers
Jul 28, 2009 | Dryers
Bottom lights do not turn off
If you have a remote for the fan and light, then it makes sense that only one wall switch operates as a master switch. Then as far as why the remote doesn't operate the lower light, the question I would have is whether the remote you have for the new fan came with it or not? If the remote you have has a button for the upper light and a button for the lower light, then you need to make sure that the reciever in the fan has wires for both lights. On the receiver there should be a black and white for the power and neutral coming from the switch. Then there will be a white wire for the neutral to the fan, a black wire going to the fan, and probably a blue wire for one of the lights. If there is another wire on that reciever (it may be orange or some other color) that would be the wire for the other light. That would be simple... four wires from the fan to four wires coming off the reciever. What you might have is four wires coming from the fan, and three wires (other than the black and white which connect to the wires from the switch) coming from your reciever. The way around that is to connect the two lighting wires from the fan to the one lighting wire from the reciever. Then when you press one of the light buttons on the remote, the upper and lower lights will always come on together. The other possibility is that there is a problem with the lower light kit itself. I would first check the wiring inside the canopy of the fan where the receiver most likely is.
Jan 24, 2009 | Hampton Bay 52 In. White Redington...
Can't find light kit to fit 52" Hampton Bay ceiling fan
I've found that Hampton Bay has it's own light kits, available only from them. The others (generic) aren't the same size. Hampton Bay fans are made exclusively for Home Depot. They are made by a few different manufacturers but only Home Depot sells them. I would have Home Depot customer service get a brochure for you so you can order what you need, if they don't stock it.
Dec 31, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
Jan 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay AC434-NI Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
