Question about Frigidaire Affinity ATF7000ES Front Load Washer
What does error 20 mean - Frigidaire Affinity ATF7000ES Front Load Washer
    Scholar:
  • 68 Answers
YOU DRAIN PUMP IS MOST LIKELY CLOGGED, IT IS REGISTERING THAT ITS TAKING TOO LONG TO DRAIN
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Posted on Dec 11, 2009
What is code blinking 20 on noritz tankless hotwater heater N_069M
The error is a HIGH LIMIT THERMAL ERROR. That means Calcium buildup has appeared in the unit. It is also called scale. To clear the error you have to power it off. That is done by the circuit breakers. You should descale the unit first though.
Jul 26, 2014 | Noritz Water Heaters
The computer panel says f 20, what does that mean?? And when I turn the washer on, I noticed that no water is going into the machine?? why??
The error "F20" means : Water Inlet Problem - no water or insufficient
water supply.
Several possibilities.
Have a look at this forum - several tests must be perform to clearly identify where does problem comes from :.
http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/10201-fixed-whirlpool-duet-sport-f-20-error-code.html
Good luck
Jan 24, 2011 | Whirlpool WFW9400S
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Hp3650 won't print from web page (error #20)-prints non web sourc
Hi scebulko:
Error code #20 means that the printer has received maore data from the computer than fits in availiable memory.to avoid this in the future you need to upgrade your memory.
pdouglasss
Dec 10, 2008 | HP LaserJet 3600n Printer
Panasonic workio DP-3530 error code E01-20
e1-20 means " laser unit horizontal problem" its ether your lsu is not connected or defection or you spc board is not connected or defective.
good luck
Nov 19, 2008 | Panasonic Workio DP-3530 Copier
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error code
sure is it e4 20?
or maybe e3 20?
if this error alway displays, it means that your machine is having problem with main motor rotation, pls contact your service provider.
May 23, 2008 | Panasonic DP-6010 All-In-One Printer
Error code E:62:20 meaning
errorE:62:20 related to lens unit stuckup or gears problum repairable
Apr 14, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Washing Machines Logo
134 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
