Question about Danby DMW1153 Microwave Oven
OUr Danby DMW1145SS microwave appears to have a blown fuse. How can we replace the fuse?
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave will not heat up food.
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Oct 10, 2009 | Danby Microwave Ovens
How much is the cost for a new Household Microwave Oven (Danby)
To replace your model of Danby.... costs around $90 bucks. To fix ur Danby if its broken.... $65/hr service charge (minimum) plus parts.... We are in the disposable society, sad... but its cheaper to throw ur microwave away unless u know the basics to fix it ... like a fuse replacement. Otherwise,.. just go out and buy a new one.
Apr 03, 2009 | Microwave Ovens
Second heat limiting fuse is blown. require the temp.specs to replace it. only indication on burnt out unit is 105 LC.
TAKE THE MANUFACTURER AND MODEL NUMBER FROM THE UNIT.THEN TAKE THAT INFORMATION AND THE FUSE TO YOUR LOCAL APPLIANCE PARTS STORE.THEY CAN
MATCH IT UP FOR YOU.YOU CAN ALSO USE THE INTERNET TO DO IT YOURSELF.JUST TYPE IN THE NAME AND MODEL # OF THE UNIT.
Mar 07, 2009 | Danby DMW1146SS Microwave Oven
Danby 1000 Watt Microwave is completely dead. Just stopped working right after heating up a dinner.
you may have just blown a fuse inside the microwave or the transformer inside has now failed and will need replacing but it will need to be looked at to see what exactly happened
electech
Nov 27, 2008 | Microwave Ovens
Not working
Sep 18, 2008 | Danby DMW1153 Microwave Oven
Danby microwave
Check if your fuse is still ok. If the fuse is gone replace and see if it is working.
Jan 06, 2008 | Danby DMW1400 Microwave Oven
Microwave Ovens Logo
104 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
