Question about Hitachi 65F59A Television
Hooking up my sorround sound dvd combo to my 65f59a tv
I need all the help i can get i bought this set used and dont have a owners manual. thanks
  • quigley10153 Jan 23, 2008
    i could not find my tv on there unlessthere was something i missed thank you for trying
  • Hitachi Master
  • 8,617 Answers
I found the owners manual at the other site i work for. It con=vers all the F59 models from 51 inch through 65F59 Hitachis. I moved it to the front page so you could find it easier. It sell for 9.99 and they will email it to you instantly if you return to the site and request they email it instead of mail it. Its 75 pages and explains all hookups and features of your projection TV. Hope this helps here the link to the site.
http://servicemanuals.vstore.ca/
Posted on Jan 20, 2008
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    The girls in the office set up aother section called owners manuals and have placed your manual there. If you return to the site and click on owners manual you will see your model listed there for you.
I need help getting a manual for my tv so i can hook my dvd vcr combo up My tv is a 37ld450 flat screen> If you dont have info on ownners manual can you help me hook up the red yellow white wire...
What is the name and model of your tv?
There are two ways to hook up a dvd/vcr to at tv.
1. Coaxil Cable - From VCR Cable Out To Tv - This goes to the tv cable jack. Tv should be on channel 3 or 4 to use it this way.
2. There are Yellow, Red, White Jacks on the vcr/dvd player. There should be a couple sets actually. One set should say OUTPUT on them. The colored jacks go from the vcr/dvd OUTPUT and goes to the same color jacks on the tv that say INPUT
TV must be on an A/V or Input channel for this to work
That is about all there is too it. If you need more info, just let me know. I am more than happy to help.
Mar 30, 2011 | Televison & Video
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
I can't get to work the set up function on my remote control
You must look into the owners manuals of both units and check the correct set-up procedures.Check to see if the remotes for both units must be used for playing dvds.Check to see in you using the correct output to input cable connections. If you are using a third unit in the hook-up look in the owners manual for the correct connections and the correct setting for the use of it with the other two units.The only way to be sure you have you hook -up correct is by useing the owners manuals, because the have all the details for these set-ups. Hope this helps you with your problem.
May 12, 2009 | Cyberhome CH-DVD 300 DVD Player
No sound from speakers when tv is on
It is likely that you do not have an HDMI cable connecting your cable/satelite set top box to the reciever. If you you run coxial striaght to your TV you will need a digital tuner and run the audio componet cable to the receiver and picture cable to the TV. Also be sure that TV out is perferably with optical audio. Hope this helps. If not its all listed simply in the owners manual. Try Sony's website if you lost it.
Apr 05, 2009 | Sony HT-SS2000 Theater System
Help With My Rear Speakers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Oct 07, 2008 | LG LHT854 Theater System
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Hitachi 65F59A Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
