Question about Maytag Neptune MAH5500B Front Load Washer
Door would not open so we used the ripcord in the dispenser to open it manually and now it will not lock so there for will not start!!!
Please help Asap
  • Anonymous Apr 01, 2008
    Hi, I have the MAH5500B also. It quit spinning and a "lr" showed on the display after a couple of minuets. Took the machine apart and found the trouble shooting (TS) guide stuffed under the control panel. Ran the test and the motor will not spin. Unpluged J4 on the control board as instructed in the TS guide. The motor would still not spin. The door locks and unlocks and all the other tests worked. Pulled the motor board out and found R18 or R19 (next to R29) blown. Would the motor cause the board to go bad? Or possibly just the board is bad? The board shows Model # AA20630 AND P/N 6 2713980. Thanks for any help.
  • 51 Answers
You need to replace the wax motor, part # 12002535, every time you pull the ripcord. The cord is made to break the wax motor. Also check the control board to see if the R-11 resistor is burned out and replace the board if it is. Congrats if it is not, the control board and wax motor work together and if one is inop it will burn out the other.
Posted on Jan 20, 2008
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge and the front panel to the front shroud assembly. Do the same to the two screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of the cabinet by grasping the upper part of the front panel posts and pressing in on the outer edges then twisting it inward. Once the front panel posts are released from the cabinet, tilt the front panel away from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
My washer is making a buzzing sound and does not start making sound from where latch is will not release the door its staying locked . the code its showing is FL and DO.
if you open the dispenser door on top of the washer, and feel around the front you should find a little green ripcord. pull on the cord until the door releases. most likely the wax motor in your door latch is fried.
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Apr 29, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer MAH 5500b FL code and door will not unlock.
Open the detergent dispenser door on top of mach. There you will find a small yellow nylon cord, pull on the cord and the door should open
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door locked
Lid lock failure Replace switch, linkage, lock solenoid or control board.
This is what you will need to check and replace
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
NEPTUNE DOOR LOCK
You may find help at ttp://www.applianceaid.com/neptune3.html#lock
the Neptune's have a manual release cord
Jul 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
366 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
