Question about Kenwood XD-A700 Shelf System
Disc player wont open & comes up with protection on screen
How do I stop the player from trying to load a disc?
if you put one of the clear plastic disc that come with writeable cd's to protect them, place that in the tray you should be good to go.
Jan 08, 2016 | Televison & Video
RCA drc200n dvd player turns on & reads disc but
divx(R) protect video dvd model no.E370
Jun 09, 2013 | Televison & Video
The screen says protect and it wont come off the screen or play radio or cds what do i do?
This radio is equipped with an anti-theft device, if the battery power is disconnected from the radio for more than a few minutes, it goes into lockdown or "protect" mode. The only way to get the code is to call the manufacturer with the product number and serial number, generally they will verify your identity and then provide you with the unlock code.
Jun 21, 2010 | Kenwood KDC-MP235 CD Player
There is a disc jammed in my cd player and the tray sometimes opens and closes but wont bring the disc out
Hi
Thanks for using FixYa. Locate your CD player’s manual Eject button. It is usually a small hole located underneath the CD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the CD and see if there is a problem with it. Most CD player drawers get stuck when a CD is warped or the label is starting to peel. If the CD is warped, discard it. If the label is peeling, remove the label.
To open the CD player top to remove the cd/CD manually--
  • Unplug the CD player and take the outer casing of the CD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending CD tray finally comes to rest within the CD player. It’s the part that holds the CD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
 Before you remove the CD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
 Use the opportunity while you have the outer casing off to clean the lens of your CD player.
 Never work on an electrical device that's still plugged in.
 Opening a CD player may negate the warranty. Read your warranty carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | GPX KC318S CD Player
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Bdp s-300 wont play sometimes?
Hiii...
Mybe it's have " safe protect " what usually sony used for their players.....
Thank's
Mar 14, 2008 | Televison & Video
Kenwood XD-A700 Shelf System Logo
26 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
