Question about Brady 2461 Thermal Label Printer
Ribbon take up not turning. Looks like it is slipping
Yellow light is lit (Empty/Pause) but there is paper in printer.
I've found that if the ribbon core is slipping on the TTR supply hub, it causes the ribbon sensor to think the ribbon is not moving. This, in turn, causes the yellow light to come on. Take off the ribbon and replace hub core locking bracket (p/n: 065375-003). I have also found you can bend the bracket enough to work if you don't have any on hand. I hope this helps with your problem.
May 03, 2011 | Intermec 3400E Thermal Label Printer
DOESN'T SEEM TO HIT HARD ENOUGH ON RIBBON TO MAKE COMPLETE LETTER ON PAPER, IT'S LIKE YOU ARE USING A OLD RIBBON THAT HAS ALREADY BEEN TYPED ON ALSO AFTER A FEW WORDS IT STARTS PRINTING DIBBER. WHEN I...
could be a defective ribbon, try new one if it looks like the letters are almost typing on top of each other on the ribbon. it could be a problem with the ribbon drive of the printhammer. if a new ribbon doesn't help, get professional help.
Feb 17, 2011 | Brother GX-6750 Typewriter
Please can you send me a picture of how to install the ribbon in to the Remington Standard No.12 typewriter. Or tell me how to thread the ribbon.
Hi, first of all there is no picture diagram for this and this method am giving you is what has been used to install ribbon on different typewriters.
  • Remove the existing ribbon. Note the path that the ribbon takes as it goes from one spool to the other.
  • Roll the ribbon entirely on to one of the two reels if your replacement ribbon didn't come with a take-up reel. If your new ribbon has a take-up reel, skip this step.
  • Attach the end of the new ribbon to the take-up reel if your new ribbon doesn't already have one. In most cases, there is a sharp arrow shaped piece on the reel. Use that arrow to penetrate the ribbon and make a few winds of ribbon around the take-up reel.
  • Slip the take-up reel on the take-up spindle on the right side of the typewriter. Align any tabs designed to turn the reel to move the ribbon during typing.
  • Feed the ribbon through the path you noted when removing the old ribbon and place the main ribbon on the spindle. Give the take-up reel a few turns to make sure the ribbon moves freely through the typewriter mechanism.
Jan 18, 2011 | Office Equipment & Supplies
How do I install a new ribbon on the smith corona electra 220 typewriter and where can I find a manual for this?
This is a sensitive installation, i will advice you follow and adhere to the installation instruction from the the manual of you unit, you can search for the manual at manualsonline.com.
Take care.
Oct 23, 2010 | Smith Corona Office Equipment & Supplies
Turntable not turning - ribbon under turntable dislodged.
Sounds like your belt is shot. Go to www.mcmelectronic.com They have belts and belt kits which will solve your problem. To replace the belt remove the platter. May mean removing a circlip off the stem. Then lift the platter up, remove the bad belt and install the new belt. Generally the belt has to be reinstalled on the platter by holding it with a screwdriver while you turn the platter slowly and work the belt on. If I didn't already say, remove the rubber cover on the platter. It will reveal a hole in the platter where you need to do the alignment work. Let me know how you make out.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Audio Players & Recorders
How do I replace the ribbon in an IMB typewriter
press down the ribbon rewind lever on the left side of keyboard until all of ribbon is wound around left spool. Remove used ribbon spool and replace with new one. Guide the end of the new ribbon through the guides to the right take up spool - looks like a bow tie. Slip the metal end of ribbon in slot and you're ready to type.
Jan 03, 2010 | IBM Office Equipment & Supplies
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
PRINTER WON'T PRINT WITH COMPATIBLE RIBBON
You need to go to setup and scroll to options menu, there you'll find :"Ribbon check" , turn it off and your good to go!
Nov 10, 2008 | Printek FormsMaster 8003 Matrix Printer
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Ribbon Slips Off Okidata ML 395
Your printhead is in correctly but not aligned, Please loosen the 2 screws that holds the printhead.Remove ribbon(all this while the printer is powered off) Now look on the right side there is a lever that makes the printer go closer to the ribbon ,move the lever to number 9 and move the head over to the left side of the printer.push the head forward slightly towards the black roller and tighten the 2 screws again ,install the ribbon and move the blue lever to 1 and try printing again.
Hope this helps.Dezzi
Oct 22, 2007 | Okidata 591 Printer
Brady 2461 Thermal Label Printer Logo
20 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
NOEL
NOEL
Wade Mobley
Wade Mobley
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
