Question about Sony BDP-S350 Blu-Ray Player
Static like picture on blu ray screen
My blu worked perfect for four days, but now the picture is really bad.
Vrya
  • 62 Answers
SOURCE: bdp s-300 wont play sometimes?
Hiii...
Mybe it's have " safe protect " what usually sony used for their players.....
Thank's
Posted on Mar 14, 2008
Agent Jason
  • 78 Answers
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Posted on Jul 23, 2008
SOURCE: Blu-Ray player not reading Blu-Ray movie
Go to sharps website and download updated firmware version for your model, then transfer the file to the blu ray using a usb mass storage device. I had to do that to mine it would not play new blu rays and i just bought the darn thing should've come updated. Good luck!
Posted on Dec 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Need To Unlock My Sony BDP-S500 To Play Imported DVDS And BLU-RAY
It is illegal to change the zone on a DVD or Blu-Ray player. You should invest in what is called a Multizone Blu-Ray Player - it will play any disc from any region. That is the only legal answer I can offer. YouTube does, hoewever, feature hacks on unlocking the region code - but it is still illegal.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
  • 36 Answers
SOURCE: Our Sony Blu-Ray BDP-S300 will play older Blu Ray
Try to update the firmware on the player by going to this website http://www.blu-ray.com/firmware/firmware.php?id=10 the newest version is 5.20 fixes alot of problems including playback issues with some BD movies and safe the file into a flash drive and plug it in on the back USB port, go to menu/firmware update run the update.
Posted on Jan 12, 2010
So i ordered a new power supply board for my LG 55la7400 television set...part was a perfect match..it went on smoothly with no issues whatsoever. Still just comes on and then black screen
Is it the same as it was before? If so You may have replaced the wrong board, but chances are if tv has a back light it's the problem. It would prob. be cheaper to have a tech. fix it the long run. You might try youtube videos they might help solve your problem. With electronics today their cheap & they don't last long.
Nov 10, 2015 | LG 55LA7400 55-inch 240hz Cinema 3D Smart...
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
When I turn on my WS65611 rear projector TV the picture comes on perfect but after a minute it starts going static then the picture will come back on then it goes stactic. This continues for as long as the...
A few things you could and should try, try something on a different input if you are using the coax connection just to know if problem exists that way, could be a bad tuner but that can be got around, also if on all inputs the set does have a hard reset that requires the Mitsubishi remote and a four digit code to enter the hidden option menu.
check the other inputs first please and let me know.
Aug 27, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Great picture but really loud static when watching dvd
Hook the DVD to another TV set, this will prove if the player is the issue or original TV
Mar 19, 2012 | Yahoo Diamond Vision DVDC803-04 DVD Player
Hd picture
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Jun 01, 2010 | Sony STR-DG820 Receiver
Ice Age blu ray sound is bad
i have the same exact problem - help!
Jan 05, 2010 | LG BD390 Blu-Ray Player
Unit quits after 10 minutes/ screen black and static- noaudio files on card
I call this a problem with a capcitor inside the unit has leaked or has bulged.. Witch is not provding the power it needs to function properly see www.badcaps.com just for a example what are bad capcitors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 24, 2009 | Astar PD-3015 Portable DVD Player
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Sony BDP-S350 Blu-Ray Player Logo
181 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
