Question about Brother HL 5250DN Laser Printer
Cat jumped on top of printer and 2 pieces popped out
I have a Brother HL-5250-DN printer.
I have a skinny black plastic roller with 2 pairs of rubber pieces and a round gear like thing at 1 end. Each end has a little post that looks as though it should fit in a hole or slot but I can't see where exactly.
There's also a very small white plastic doughnut like piece with a little tube on top and three tiny tabs around the doughnut. The opening is a little bit larger than the ends of the black plastic roller. Looking at the rear of the printer, I can see another white piece up at the top on one side of the printer but I have no idea how to put this piece back on the opposite side without dropping it inside and losing it somewhere.
I would need a detailed diagram that's big and easy to follow in order to put these parts back. Can't find anything like that.
  • agave Jan 20, 2008
    Additional information for my post - photos of the parts
  • 417 Answers
Hi there you will have to remove the top cover and you will be able to see where it goes as the roller in question is the paper eject roller. there are usually four screws under the top cover and also at the rear of the machine. The picture where the roller is resting on the top of the printer the roller is situated right under that also that white bushing holds the roller in at one end usually the left as you look at the machine from the front.
Thanks J
Posted on Jan 30, 2008
6ya staff
SOURCE:
Brother HL 2140 does not pick up paper from tray
Make sure your pickup roller clean.
If it's clean and still jams the problem is inside.
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist
PhillyCopiers.com 215 364 3774
Apr 09, 2010 | Brother HL-2040 Laser Printer
2070 printer shows red, flashing 'paper' lcd when there is paper in the tray. I have done the usual, checking tray, removing and restoring toner cartridge etc etc. I have tried a manual feed as this...
Dec 01, 2009 | Brother HL-2070N Laser Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
Brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
[email protected]
Jan 19, 2009 | Brother HL 5250DN Laser Printer
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250 DN status shows "error". Won't print.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 26, 2008 | Brother HL-2070N Laser Printer
SOFTWARE DOWNLOAD NEEDED
Need software for Laser HL-5250 DN
Apr 27, 2008 | Brother HL 5250DN Laser Printer
HL 5250 dn
first you most clean the printer carefully then you most change the drum unit
Feb 28, 2008 | Brother HL 5250DN Laser Printer
Brother 5250DN printer noise
Check my solution here:
http://www.fixya.com/support/t641678-paper_tray_noise
Here's a solution for you with Brother HL 5250 D/DN/DNT
Change the paper setting tab in the tray to make sure you have a small gap between the top part of the paper and the bottom part.
so if this is the old settings : |paper| --> you want to make it: | paper| so you can have slide the paper back and forth.
DON'T adjust the setting to the next paper size because the roller wont catch the paper if it slide too far.
Good luck to all.
Nov 02, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
74 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
