Question about Kenmore Washing Machines
My kenmore clothes washer is grinding on the spin cycle. It is not the coupling because I just changed that. I am thinking that it has something to do with the gearcase. It almost sounds like a shaft somewhere is hitting something as it is spinning. It is loud.
    Scholar:
  • 68 Answers
THE SPIN BASKET ON YOUR MACHINE SITS ON A PART CALL THE DRIVE BLOCK. THIS CAN BE BROKEN.
YOU WILL HAVE TO REMOVE THE AGITATOR. UNDER THAT YOU WILL SEE A BIG NUT WHICH IS TIGHTENED ONTO THE "DRIVE BLOCK. LOOK CLOSELY NEAR THE CENTER OF IT AND YOU WILL TWO EARS THAT COME UP SLIGHTLY TO JOIN THE DRIVE BLOCK. THE EARS COULD BE NOT CONTACTING PROPERLY AND ALLOWING IT TO SLIP. THIS CAN SOUND LIKE A MACHINE GUN SOMETIMES.
OR, THE DRIVE BLOCK IS JUST BROKEN AND ALOWED THE SPIN TUB TO SLIP DOWN AND NOW ITS RUBBING AGAINST THE OUTER SHELL.
PART NUMBER - 389140
BUY IT HERE- http://lartoday.com/order_parts.htm
LEVI
LEBARCHRIGEN APPLIANCE REPAIR
WWW.LARTODAY.COM
Posted on Dec 11, 2009
I have Kenmore washer,model #110.28882790. grinding noise when in spin cycle. not spinning! What is possible defects?
Sounds like the washers drive coupling is broken. Part number 285753A. The coupling connects the motor to the transmission and when it breaks it can make a grinding noise. Since it is not turning the transmission anymore it cannot spin. Hope this helps
Aug 30, 2011 | Kenmore Washing Machines
Our Kenmore top load model 22422 started having problems with the spin cycle. Once it gets to the spin cycle, it makes a terrible grinding like noise - it is not spinning. However it will drain if you let...
The double shaft motor does double duty. One direction for wash and another direction for spin. In wash mode the water stays put in the tub because the pump is running backwards. In spin mode the motors turns in opposite direction. This pumps the water out and spins the clothes dry. From what you have described the drive coupler is toast.
This video shows how to swap the drive couple out:
More HERE
Mar 01, 2011 | Kenmore 22422 Top Load Washer
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
THE DRUM OF THE WASHER DOESN'T SPIN
drive coupler, or something stuck in between the tubs. there is a couple of things that can do that
Oct 07, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore model 23832100 washer will not spin in rinse cycle
the motor it's self may be getting weak this happened to me.try running it through a small cycle with no cloths in it .holding the buton down under the with a small object so you can have the lid open to see exactly what's going on.if it seems too work like that.your probably talking new motor.
Jun 02, 2009 | Kenmore 22422 Top Load Washer
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series washer
yo cna search ht e you tube sight for a visual refence to removing hte console/wrapper off the machine. soundsas if you have a bad motor coupling, this machine equivelint to the belt. youll find vids to replace that too
Dec 03, 2008 | Washing Machines
Kenmore 80 Series Heavy Duty Super Capacity Plus
that is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
