I have a home network with ethernet connections thru out the house. I have an on-Q 4 port router and an ethernet switch. I just bought an iMac and have been trying to get it to print on my network printer without success. The computer and HP printer see each other with an IP address but not without. I get a message saying the network server is busy when I try to print. I have talked to the HP techs any they referred me to a router technition.
    Brigadier General:
  • 10,406 Answers
Instead, talk to a Mac-guru, in a computer-store that specializes in Apple computers.
Posted on Dec 11, 2009
All 4 ports want to set up as Wireless; I want all 4 Ethernet
Connect the Ethernet cable directly to the Ethernet ports on the router. That should work. There may be a setting in the routers configuration to disable wireless if that's what you want.
Feb 01, 2014 | Computers & Internet
I have two computers in the house which are linked by an ethernet cables, my wireless router only has one ethernet hole,so I would like to know what I need to buy? such as an adapter or something, so I can...
If there is only 1 ethernet port on your router it sounds like this is the port for your modem to connect to your router and that your router is only built for wireless. If you want to connect computers via ethernet cable you will need either a new router with a 4 port switch or a new wireless router with a 4 port switch. (you can get more than 4 ports if you have more that 4 computers).
Mar 03, 2011 | Office Equipment & Supplies
Central home network
(add small 4 port hub) from cable router out to hub port 1.-take cat5 from central insert in port 2 of hub.- insert cat5 in port 3 of hub then other end in now open cat5 port
Jan 03, 2010 | CommScope 1000 FT RG6 QUAD/CAT - 5E 4 -...
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
IPAQ RX3715 can't log on to home network
Try upgrading the firmware on the router and then connect the IPAQ and computer to the wireless network
Jun 11, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Wont connect and software cd
To connect a router or a dsl modem to a switch you either have to use port 4 or use a utp crossover cable. As you can see on the Netgear FS605 the modem/router has to be connected to port 4.
The correct way to connect these devices is:
Modem > Router > Switch > Computers
Jan 14, 2008 | NetGear FS605 (FS605SE) Networking Switch
Network key
Lkrawlings:
Can you go into your router from IE? like http://192.168.x.x, then from this configuration page of your router you can find what key you had put into your router. Make sure the type of security you are using like WEP, WPA, PSK, WPA2 etc. This key should match on your desktop or laptop machine to gain connection to your router.
If you are unable to find your key like this then:
You could refresh your router to factory defaults by pressing for 5 seconds, you will find this hole at the back of your router. try going again into your router like I said above and make up any other key.
Hope that helped!
Dec 07, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
