Question about GE GSH25JFR Side by Side Refrigerator
The frig is really a GE freezer on top model. 62D1580P002. I think the compressor is going. Is changing that out a job I can do. should I call a repairman. I tried to get the part for it and had trouble as it is old. Can you recommend a parts place in the 90065 zip code?
  • 4,070 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Replacing the compressor is a complicated job requiring special tool and training. The model number you gave doesn't match any I can find. Use this to find it.
http://www.appliancepartspros.com/modelnumber_locator.aspx Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Dec 18, 2009
I have a GE Profile TFHW24R upright Frig. Little by little the freezer stopped freezing. I unpluged it and took the back panel inside the freezer compartment out and can see ice on my coils. There are 3...
Hi, I think you may have a refrigerant leak...but...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 03, 2011 | General Electric GE Profile CounterTop...
Fridge starts for about 30 seconds then cuts out and No 5 light starts flashing,not in possession of a manual so would like to know what the problem is,sounds like the thermostat but who knows.
I think your start relay, run/start capacitor and overload on the side of the compressor need to be checked or replaced. What is happening now is called short cycling and if the refrigerator remains plugged in the internal overload could fail and really become a mess. If your refrigerator is a GE Profile, Artica this solution will focus more on the mother board. More on how to test compressor and locate model numbers HERE and near bottom of page. How to Test a Compressor,Thanks, Sea Breeze
GE APPLIANCE MODEL NUMBER LOCATOR'S
Refrigerators
Freezers
Jul 15, 2011 | Refrigerators
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
GE MONOGRAM FRIDGE. FRIDGE TOP FREEZER BOTTOM. COMPRESSOR IS HOT, EXTERIOR BETWEEN FRIDGE AND FREEZER IS HOT. WHAT'S WRONG?
nead to know more, the area between the frig and freezer has a heater in it to prevent moister buildup.you can turn this off by turning on the energe saver mode.next you nead to take the kick plate off in the frount and bottom off frig.on the right you should see the condencer coil's, clean them.
Nov 22, 2009 | GE Monogram ZDI15C Automatic Icemaker
5 year old Amana bottom freezer. No cooling because compressor not working. Technician tried a starter but it short circuited. Now fridge is off. Worth buying new compressor or a new frig? Is this a...
you can have the compressor replaced for around 500usd on the norm. that would be the most inexpensive way to go compared to a new unit , it will come with a 90 day-1 year warranty.
Phil
Jun 10, 2009 | GE GTH18KBR Top Freezer Refrigerator
Kenmore top freezer frig
check your start relay on compressor. If that doesnt solve it then you need a new compressor. This is all based on the facts the you said the unit is running all the time
May 27, 2009 | Kenmore 63182 / 63184 Top Freezer...
GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Dec 16, 2008 | GE Profile Arctica Stainless Steel Top...
Freezer freezes OK, frig compartment doesnt get cold
Does the unit only have one compressor (black round object on back of unit). If yes then sounds as though you have lost some refrigerant (just enough to keep the freezer happy). If no (ie two compressors) check if both compressors hot. If both hot then have major problem if one cold then have a thermostat gone. Personally I think you have lost gas from your description, if so then you are looking at a dead fridge freezer. Hope this is of some help.
Mar 13, 2008 | Refrigerators
GE GSH25JFR Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
