Question about Kenwood KDC-W707 CD Player
THE RIBBON THAT CONNECTS THE FACE OF MY KENWOOD KDC-W707 TO THE CIRCUIT BOARD HAS SNAPPED AND I WOULD LIKE TO KNOW WHERE I COULD GET A REPLACEMENT FROM
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
Try pacparts.com
Posted on Dec 11, 2009
SOURCE:
How to reset the kenwood kdcw707?
hi there take off the face and there is a reset button under neith if not take out the fuse and leave it for 20 mins
Oct 17, 2010 | Kenwood KDC-W707 CD Player
Lost code for my kenwood kdc-w707
There are 2 types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Apr 05, 2009 | Kenwood KDC-W707 CD Player
Need info ,repair
Actually the problem is the ribbon cable,the one it connects the face to the main board.
You need to replace it.
You can get it at pacparts.com
Jan 29, 2008 | Kenwood KDC-X817 CD Player
Kenwood KDC-519 CD Player
Check ribbon cable from main board to face for breaks in the lines. Replace ribbon cable if bad.
Aug 01, 2007 | Kenwood KDC-519 CD Player
Display totally gone.
I'm not sure if your unit is a flip face, but if it is then the first thing I would suspect would be the ribbon cable that connects the flip face to the main circuit board. Hope this helps.
Jul 25, 2007 | Kenwood KDC-715S
KDC-MP919 No display
You probably have a break in the flexible ribbon cable that goes between the flip face and the mother board. Try partstore.com for a replacement cable.
May 24, 2007 | Kenwood KDC-MP919 CD Player
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Shutting Off
the usual repair for a morotized face plate with symptions of no display, some buttons working or no buttons working & sometimes even the faceplay not moving, is the ribbon backthat connects the main unit to the face plate. Sometime you might be able to see the gold/yellow flat ribbon as the face plate flips. it's not too difficult to cange but it takes patience. the cables run around $15 to $30.00.if you replace it yourself, watch out incase the spring for the ribbon tension unwinds. good luck
Dec 14, 2006 | Kenwood eXcelon KDC-X679 CD Player
Kenwood KDC-W707 CD Player Logo
241 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
