Question about Canon PowerShot SD110 / IXUS IIs Digital Camera
How do I put the camera back to default settings?
  • 1,305 Answers
1. Press and hold the on/off button until the light turns GREEN. Mode can be in any position
2. Press and HOLD the menu button for at least 5 seconds..
3. Use the side arrows to select "restore default settings?" and then press SET..
Ta DAH! you did it!
Posted on Dec 11, 2009
I have played around with the settings of my nikon s26oo coolpix camera and now it is taking very bad phot'os. Can Someone please help me to get back to the default settings??
To reset the camera back to the default setting, remove the battery for 15 mins, replace the battery then open the camera's Menu and set the Date & Time.
Feb 22, 2013 | Nikon COOLPIX Cameras
All the pictures are blurry the auto focus isn't working
You may have put the camera on manual focus. Two ways to do that.
1. There is a switch on the lens which allows you to select auto or manual focus. Be sure the switch is set on A or A/M. If it's on M, you are on manual focus.
2. In you menus, there might be a mode which is manual focus. Look in your manual index under Focus, manual. There might be a setting in the Focus Mode menu.
You can also try resetting your camera. This will put most things back to factory default mode, including the focus mode.
When playing around with controls, go step by step through the manual and try things out. Be sure to set the control you were playing with back to default unless you really understand that setting.
Apr 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I have sony DSC-W190,i want correct menu setting ,bcos if i take a picture its not clear,i think may be menu setting changed,idnt any idea about menu setting pls help.....
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Apr 07, 2011 | Sony Cyber-shot DSC-W190 Digital Camera
How to reset settings back to origional settings on my fuji finepix s1000fd digital camera
Please put the camera on P (Program Mode)
go to Menu --> Settings --->(Pg4) Restore Factory Defaults
Done!
Regards,
katharsys_i
Mar 06, 2011 | Fuji FinePix S1000FD Digital Camera
My sony cybershot camera shows in grid form when I put it iln my computer. not the fault of computer. I think I have set something wrong on my camera
You can reset camera back to factory default settings by selecting Initialize option in setting menu.
This will fix any wrong settings in camera.
Thanks.
Oct 28, 2010 | Sony Cameras
The flash on the camera does not pop up.
it is been set to no flash mode by some or other settings.if you are not able to make the necessary changes just go to menu and put it back to "reset default settings" it will automatically flash once its reset to default settings.
thanks.
Jul 08, 2009 | Fuji FinePix S700 Digital Camera
Fuzzy pictures
It's possible that some of the settings are set improperly on the camera. Try resetting the camera back to factory default settings and see if this makes any difference. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to RESET - press Ok - highlight Yes and press Ok. This will set the camera back to factory settings. Try to take some images and see if they are still fuzzy.
Mar 29, 2009 | Olympus Stylus 700 / 700 Digital Camera
Need help back to default settings
If you want to take close-up, use Macro function. Button is located at rear and have sign like flower.
Want to restore default settings, go to camera menu and select Initialize, camera will power off and on again and select all default settings.
Let me know if further info required.
Dec 14, 2008 | Sony Cybershot DSC-H3 Digital Camera
After resetting to default settings, the shooting mode screen is black
Remove the batteries and put them back in. See if it restores the camera seettings.
Jul 19, 2008 | Canon PowerShot A95 Digital Camera
Turns off after "PASS"
go to the setting and you must set to defualt function and it became in normal,,
if theres a problem for that you may also long press the reset in order to back normal your setting... inform, me if you made it so that i can determine another way to back in normal...
Jan 15, 2008 | Bushnell 11-9000 Digital Camera
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
