Question about Refrigerators
I have a Kenmore dryer that will not heat up for a full cycle. I can see the gas (bottom) Lights up and has a flame but my clothes are not dry after a full cycle. I took the dryer apart cleaned out a lot of lint and thought that might be the problem but thats not it. What do you think I need to do? I appreciate your help.
    President:
  • 1,891 Answers
Try the dryer off the vent / if it works good / then clean the vent / no dryer works good with poor air flow .. mm
Posted on Dec 11, 2009
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Gas dryer heats at first then take forever to dry, auto dry setting does not advance
If it works to begin with and fails afterwards then that can only be them solenoids mounted on the gas assembly. Here is my home video which shows how to check and replace:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2013 | Dryers
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Flame only stays on for five minuts. After start
the flame doesn't stay on the whole drying time, it cycles.The thermal fuse allows machine to work and heat up but the cycling thermostat directs the flame to come on and shut off. Do your clothes dry fine?
Mar 04, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 Series gas dryer Dryer will not heat I just moved in and the dryer has not been used in a while. What do I need to do to start it back up?
your flame will not be on all the time during the dry cycle. It cycles to prevent it from over-heating? Do you have clutter on top of it, such as clothes? If yes take everything off of it and never use the top for clothes piles or anything of this nature. When you have stuff on top it insulates it and the excess heat cannot disipate. 90% of the world uses the top for clothes piles. DON'T DO THAT EVER.
Good Luck
Feb 23, 2009 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
