Question about Comet GXD2527G Pressure Washer Pump
Pump problems we have a mobile car wash service that we use in the winter months we have a 300 gal tank and several power washers.we use 3 diffrent machines 4000psi@4 gal 2500 psi@2.5 and a3000psi @3.0 gal i;m having a lot of pump problems with all of these machines.a friend that he thinks that the hose that the machines feed of is to small 3/4'' he suggests i use a1 1/2 hose as close to the machine before adapting to the 3/4'' fitting right now it;s about12'' long away from the tank.any info would be very helpful thank you frank garcia
  • 60 Answers
Are you only using gravity to feed the machines. The law of gravity is that, for every foot of elevation you will get 2 PSI ( pounds per square inch) of pressure. You can figure out the minimum volume that the manufacture requires and make sure that amount is being furnished to the machines. You will probable need to install a pump prior to the machines with a regulated return line to keep the proper amount of water running for optimum performance. Its very hard on the machine not to have the proper volume of water. So to answer your question, i don't believe you'll be able to get 9.5 GPM that the three machine need by simple using gravity. I hope this helps
Posted on Dec 13, 2009
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
My 3 month old bosch 300 series washer isn't draining completely and errors at the start of the rinse cycle with E13 falshing along with the rinse light. Help!
the E-13 error code is a drain timeout code. This means the pump has run a certian amount of time without fully draining itself. This could be anything from a clogged drainline in your home to a clogged drainline in the machine, your pump is clogged, pump is burned up, no power to the pump, bad board etc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it). Just have to take her apart to find out for sure.
Aug 10, 2008 | Bosch Washing Machines
Tip
Winterizing your Pressure Washer
Once again it's that time of year to get your pressure washer prepared for the cold months ahead. Proper winterization will protect your pump from the freezing of excess water in the pump over the winter. There are many ways to winterize your pump; we like to classify it as the good, better and best.<br /> <br /> Good: (Gasoline powered) Leaving your machine in the off position with the high pressure hose disconnected pull the recoil rope 4 to 5 times or until you don't see any more water coming out of the high pressure end of the pump. (Electric powered) Disconnect your high pressure hose, turn the machine on for 5 to 10 seconds or until you don't see any more water coming from the high pressure end of the pump.<br /> Better: If you have a air compressor around the house, hook the air line to the garden hose end of the pump and blow the water out until you don't see any more water coming out of the high pressure end of the pump.<br /> Best: Purchase Karcher's Pump Guard, follow the simple directions that come with the product. This product is specially formulated to keep your pump from freezing, corrosion, premature wear, adds lubricant to the valves and seals to prevent sticking in the spring. You can usually get 2 or 3 uses from one bottle of Karcher's Pump Guard. <br /> <br /> <a href="http://www.wmpcs.com/blog/?p=63">Visit this link to read more</a>
on Nov 01, 2010 | Garden
96 tl, no wiper fluid coming out. is there a separate fuse for the fluid or is it the same as the wiper motor. If so where is the fuse, or where is the pump if i need to change it
you add fluid all the time so you do know where the tank is ! (engine bay)
see pump at bottom of tank?
many cars its the same as the wiper fuse.
why no just look at them all, its in the cab fuse box.
if the pump buzzes, it is probably ok, remove hose, does it pump water now? hose at pump is in near bottom of tank.
got a sun roof, they are diffrent
the sun roof , can kill the washer, via the sun roof washer relay cut out.
fuse 18 runs front wiper and washer
the roof premissive relay is FuSe 5 ,marked "wiper-washer" (roof)
now on no roof cars, that is different
fuse 6 runs it all. marked wiper-washer 30amps.
complex, huh
use alldata.com and see it all ... ever bit,
see the no buzz tests
here
http://www.fixkick.com/wipe-wash/index.html
Oct 25, 2013 | Acura TL Cars & Trucks
Ok at the place I am employed they have a 1 Hp submersible pump it pumps about 300 ft into the top of a 120 gal storage tank then the water comes out of the bottom of the tank and goes into our grundfos...
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
Dec 18, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Are 2003 and 2005 nissan frontier fuel pumps indenical?
This depends on the fuel tank size and engine size,also i research this and found that in 2003 they came with 3 diffrent engines that use 3 diffrent pumps, the 2005 came with 2 engine diffrent than 2002 and they use diffrent pump, so the answer to your question is no you can not interchange these pumps, hope this helps.
Aug 31, 2010 | 2005 Nissan Frontier
On my last fill up i pumped 33 gallons, when previous fill ups were less than 26 gallons. I have a 1999 expedition Eddie Bauer. I thought I had a 26gal tank, since with the warning light on and saying 10...
The 99 expedition comes with a 26 gal tank as standard equip. and there is an optional 30 gal available. I suspect the gas pump you used is not accurate, and needs to be recalibrated. I think it's just a coincidence that the gauge is acting up now. Hopefully I'm wrong, and by some miracle you actually are now getting 300 miles on a half tank of gas! You may have a bad sending unit, this would result in inaccurate fuel tank readings.
Jun 23, 2009 | 2001 Ford Expedition
Pump is not starting to pump water out of whirlpool ultimate 2
I suggest you purchase a lid switch from a local supplier of parts or call a local servie tech if it's just the lid switch it should not take a tech long to change it.
Dec 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Winterizing a LXIH Hobart dish washer
Joe - The main issue is that the builtin booster heater is full of water - it has to be drained - there may be a small drain plug (square-shaped head), if not, you may have to pull loose the heater element to drain the tank. I would pour antifreeze solution in there and also in the wash tank. Unhook the water inlet - you say the machine is hard-plumbed in but mfgr recommends using brauided water hose to connect to water supply. hopefully this helps - I service commercial machines and came across your question and maybe you can ansqwer one of mine - how do I cancel the "delime" indicator? I can't find operators manual. jimmy.
Nov 26, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Whirlpool® 4.6 Cu. Ft. Cabrio® HE Washer leaking water
coins may have breached the outer tub. expensive way to learn to remove loose objects fro clothes before washing them
Sep 14, 2008 | Washing Machines
Comet GXD2527G Pressure Washer Pump Logo
97 people viewed this question
Top Comet Garden Experts
John Trevino
Joseph Hoffmann
JOHN LAPIER
Are you a Comet Garden Expert? Answer questions, earn points and help others
