Question about Hawking HPS1P Print Server
Windows 7 does not find my Hawking HPS1P Print Server
  • 100 Answers
Dear sir good day try check your firmware ver and update it if not HPS1P V7.2 and thin try to connect agine and for more info please visit the link http://www.hawkingtech.com//support/details.php?CatID=21&FamID=42&ProdID=150&Rev=Orig#Software and you will find some help about the product thanks
Posted on Dec 23, 2009
Run a cnet cnp430 on windows 7
I hope you are connecting the print server to a network hub or switch and not trying to connect directly to your Win 7 machine.
There are no drivers, a print server is a network device. Connect the ethernet cable from print server to your router. connect your printer to the switch. Search the network for the printer.
Apr 06, 2014 | Cnet CNP 430 (CNP430) Print Server
Reset password on hps1p
I would suggest your download PSADMIN and Installation software from Hawking then push the reset button on the print server and start again.
Nov 22, 2013 | Hawking 10/100 PRINT SERVER MINI 1...
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Windows 7 cannot find my hawking pn7127 print server. All my xp computers print to it no problem , My port is http://192.168.1.5/lp1. Even when I input this info, Windows 7 cannot communicate with the...
1. Click "Add a printer".
2. Click "Add a network printer".
3. Click "The printer that I want isn't listed".
4. Select "Add a printer using TCP/IP". Click "Next".
5. Type in the print server's IP address. Click "Next".
6. Select "Custom". Click "Settings".
7. Change Protocol to "LPR". In LPR Settings, type in "lp1". Click "OK".
8. Click "Next". Select your printer. If your printer isn't listed, click "Windows Update". If still not listed, install driver from manufacturer's website.
9. Print a test page!
Mar 10, 2010 | Hawking 10/100M Internet Print Server...
MY WINDOWS 7 LAPTOP WONT RECOGNISE PRINT SERVER
Please note that all old devices drivers have upto windows xp or 2003 server files becuase now only windows 7 has been launched in the market. So don't worry you can download print server drivers from the site .
If your print server is USB connected , the windows 7 will say found new hardware after that it will ask you update drivers, there you can click on have disk and locate the driver files where you have kept and clickon windows 2000 or xp from here you can select the driver and install it. Defently your print server will work.
If this answer is helpful ,pls rate it.
Feb 26, 2010 | Office Equipment & Supplies
Connect Ubuntu box to HP LaserJet 4000 (printer #2 - LPT2)through Hawking print server model HPS12U (internal address 192.168.1.4) Same box (and other winxp pro boxes) connect and print fine thru...
Go to System > Hardware > Printers.
Then click on Server from the Menu, and then select Settings. Check boxes:
  1. Publish shared printers connected to this system
  2. Allow printing from internet
Click OK, then click Refresh.
You can click New to add the printer, it will search and then you select Network Printer, and find a network printer.
Feb 15, 2010 | Canonical Ltd. Ubuntu
Print server HPS1U does not seem to be compatible with Windows 7. Tried to configure a new port manually, but no luck. Any ideas?
At present very few things are compatible with windows 7 Like all microsoft operating systems they are released without much consultation to the millions of players out there that need to produce a driver that will work in microsofts ever changing untested software.
In future never rush out and buy an MS new op system leave it for 12 months till industry catches up and all the bugs have been removed with a million patches etc.
Some companies use Beta Testers, Microsoft users Clients and there lies the lesson. Contact HP and see when they will be able to supply a new driver for this unit.
Please rate my help++++Thanks for using FIXYA
Dec 02, 2009 | Hawking Internet Print Server H-PS1U...
Cant find the Print Server IP
when you tried to ping the restored ip for the print server did your computer was in the same subnet? if not try to configure your machine ip to be in the same subnet for your print server ip.
Jun 14, 2007 | Hawking HWPS1UG Print Server
Hawking HPS1P Print Server Logo
1,754 people viewed this question
Top Hawking Computers & Internet Experts
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
