Question about Swift 779 Birdfeeder (10x40) Monocular
Dropped unit. Knocked the prisims loose. All
Dropped unit. Knocked the prisims loose. All glass appears okay. No cracks chips or scratches. I paid $90.00 for the monocular. Is it economically practical to try to have them repaired?
    New Friend:
  • 61 Answers
It's quite easy to dismantle and inspect, look for tiny retainer screws around eyepiece and/or unscrew lens shrouds. Normally the prisms shouldn't come loose in average to good quality viewers, they'd be held in by some sort of retainer, eg- flexed, spring tempered metal, where you screw in one side and then have to flex (bend) the metal to screw in other side over the back of the prism. It sounds like yours may use an adhesive retainer, if so clean of old residue and use fresh silicone, or may have broken the clip and or screws. But it may just have popped out, in which case reattach it. Make sure the prisms are seated properly, 1 hardly visible flake of glue or dirt under the prism will offset vision noticeably. I would say you may be lucky and find an honest repairer for about $45.00 if prisms aren't damaged.
Posted on Dec 11, 2009
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
www.sears.com
www.apdepot.com
www.repairclinic.com
Jan 21, 2011 | Whirlpool GJC3034 Electric Cooktop
I dropped it and now it is not listed in my computer area. I have limited computer expertise
This problem was posted under a heading for an internal hard drive. If this is what you have and dropped, your drive may be a goner. Hard drives don't take kindly to being dropped. They're a mechanical device with close tolerances, and enough of a shock can damage them so they no longer spin or read. Shock can also crack the circuit board or break components loose so the drive stops working electronically even if it's mechanically okay.
On the other hand, if this is an external drive in a case, there may be hope. The drive itself may still be bad, but you might simply have knocked an internal connection loose. In external drives, there is an interface board containing some power circuitry, the external power jack if one is used, and connectors which plug into the drive inside. The board may have been damaged or the connections knocked loose, while the drive survived. The only way to know for sure is to open the case and remove the drive, then connect it into another computer for testing. On some cases this is fairly easy, while on others it's like breaking into a bank vault. You can find disassembly instructions for most brands and models on the Internet.
I hope yours works out. Good luck and thanks for using Fixya!
Dec 28, 2010 | Western Digital WD Scorpio Blue WD2500BEVT...
I just shatter the top of my stove ,glass ceramic, can it be repaird.. it's a glass cake cover fell handle first and 3 of the burners have cracks running through them ..do i hve to replace it or can it be...
Unfortunately no your ceramic glass top cannot be repaired and will have to be replaced. as for the burners as long at the metal heating part of it isn`t damaged and its just the outer white coloured insulation that is cracked or chipped this is okay and still operate normally.hope this helps
Thanks
Oct 12, 2009 | Maytag Ovens
I accidently dropped a glass jar onto the edge of my ceramic hotplate on the side where the controls are there is a chipped area about the siz of a ten cent piece and a hairline crack about 3cms in length....
Ordering the broken part and replaced it - that is the best solution for safety purposes. send us the model number of your unit- we get the part for you or call any repair man to fix it for you.
Aug 03, 2008 | Kitchen Ranges
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 | Cooktops
Motorola Razr V3 Screen looks like broken glass on inside :-/
if the black lines u see across the screen looks like leaking ink, then it probly is, suggest u get a replace lcd for your phone
Nov 25, 2007 | Motorola Mobility RAZR V3
Swift 779 Birdfeeder (10x40) Monocular Logo
153 people viewed this question
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Tom Chichester
Bill Boyd
Are you a Swift Optic Expert? Answer questions, earn points and help others
