Question about Philips 50PL9126D/37B 50" DLP TV
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise everything else looks fine as far as I can tell.
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Posted on May 17, 2010
  • familyrhode Sep 28, 2010
    So, did a new bulb solve your problem?
Have u found a answer to the problem my tv is doing exact same thing
Posted on Jan 16, 2010
  • 1 more comment
  • skiles1964 May 06, 2011
    i changed my bulb. will play for a while and go out but still have sound. brand new bulb.
  • Kristine Schell Apr 19, 2013
    I am having exact same issue...the contrast gets funky and then the screen seems to flicker is best way to describe it.
    I have same issue. It will run for good hour or so then the contrast gets funny (peoples hair and heads look funny colorwise) then the screen has a slight flickering to it. I will shut it off and I cannot turn back on until bulb has totally cooled. Yes, Brand New Stinking Bulb.
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
My Phillips 50PL9126d/37 is making a loud humming noise and the picture color is barely there.
Hi, Sounds like a bad color wheel. If you know what your doing you can get one on E-bay for around $170. In the past the whole light engine would need to be replaced $700 ish.
Good Luck
May 20, 2013 | Televison & Video
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
Have a phillips 50pl9126d/37 put new bulb still no piture or sound
bearsdis,
I have a tip at http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which explains the troubleshooting procedure and where to get any parts that you may need.
Thanks for using FixYa and for the great rating.
hardrocko
May 26, 2011 | Philips 50PL9126D/37B 50" DLP TV
My Philips tv 60PL9200-37 has sound,but NO picture. The front blue light flashes 6 times slow,pause,5 times fast. Once in a blue moon picture and sound are ok. What could be wrong?
When your television actually flashes the front blue light, it is passing a message that there is a problem inside the unit. There are 2 things you should check but my best bet is that it is the t-con board of the television that is bad. The other component you can check is the lamp, but if the lamp is faulty you will not be getting sound therefore the problem is from the t-con board.
It is located by the middle of the main panel of the television, once you get it replaced, the television will be in good shape.
Take care and good luck
Jan 02, 2011 | Philips 60PL9200D Projection Televisions
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
Philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Problem
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 50PL9126D/37B 50" DLP TV Logo
2,165 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
