Question about Samsung DTB-H260F
Unit will only stay on for 20 sec. after you unplug it for about 30 sec. Blue power light can not be turned on again unless you unplug it again. Unit is not functioning with the light off, so it is not just the power light circuit. Unit is about 3 yrs old. Has worked well until now. Thanks, Jim
  • 19 Answers
Your dtb-h260f likely has a bad capacitor in the power supply. See this link for more information: http://www.badcaps.net/forum/showthread.php?t=7804
Posted on Feb 04, 2010
I just had the same problem on my samsung DTB h260 on Dec 20 2009.I am trying to search a answer.A nephew brought his WII remotes over and his Wii remotes lite up and my wii and dtb h260 shut off.Had to unplug Wii and replug it into wall. It started up but the dtb h260. Wierd like interference.
Posted on Dec 27, 2009
  • Fairlanegt Dec 27, 2009
    My Unit will only stay on for 20 sec. after you unplug it for about 30
    the power light circuit.My did this on Dec 20 2009. Nephew came over with his 2 wii remotes. His wii remote lights lite up flashing and my wii box and samsung dtb 260 shut off.Had to unplug wii box for 20 min and replug it in.It works but dtb 260 is doing the same thing as your box. It acts like interference happen but weird.
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Tv stays on for 15-20 minutes and then picture blacks out, Can't turn back on. Unplug and plaug in again but still only last 15 - 20 minutes. new lamp, no difference.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Sansa e250 wont turn on, help
I found the solution to our problem!! and it is very easy. Take the 4 screws off the back. Remove the battery. Press the on/off switch and all the others on the front. Replace the battery and the screws.
Mine needed to be plugged in again, but the computer could read the Sansa and I can see the screen again. Now it is charging and I think that the problem is fixed.
Feb 27, 2008 | SanDisk Sansa e250 MP3 Player
Hold menu down 20 sec. will not come on,hook up pc show full battery.sanase250
Try unplugging it from the computer hold down the small power button until any light on it turns off.
Move the button on the top from right to left
Turn on.
Dec 06, 2007 | SanDisk Sansa e250 MP3 Player
TV shuts off
I would suggest that you guys turn the unit off when this happens, unplug the unit for 30 seconds, plug it back in, and see if this helps. If this does not solve your problem, you should call 1-800-448-2244, so a service center in your local area can be found for further assistance.
Nov 08, 2007 | Televison & Video
Samsung DTB-H260F Logo
462 people viewed this question
Jerry Greenberg
Jerry Greenberg
