Question about Kenwood DNX7100 Car Video Player
Screen Tilt I can't get my monitor angle to be flushed. When I adjust the monitor angle to -1 or 0 the monitor angle jumps to angle 3. I can only set to angle 1 but not 0. What would be the problem? Would it be the install kit/harness?
  • inputapmech Nov 29, 2008
    I have a brand new unit doing exactly the same as you. Its not an install problem if the screen is not hitting something. Its a software glich from kenwood and happens to alot of them with no support from what I've heard.
    I'm thinking about returning my unit for a refund.
Mine did the same thing. If it is not aligned properly this will happen. Take the kit off from around the unit. Then tell it to go to what ever screen setting you want. If it works with the kit removed this is your problem.
Posted on Feb 09, 2008
When tilting the motor down it jumps and bangs until it gets to the trim pistons, what is causing this?
Power Tilt and Trim Maintenance Makes a Difference ...
Tilt and trim adjust the angle of the motor and thus the running surface of the boat, ...the grip on the water, the ability to jump on plane and many other operations ... be around the base of the ram, or drip down around the power tilt and trim motor. ...Sometimes you can bang on the power tilt and trim motor with the head of a ...
Jan 10, 2016 | Boating
How do I adjust the screen tilt and height? HELP!!!!!!
Hi, Here is what I was able to find out about your monitor from ViewSonic. There is no manual available on their website.
I have two ViewSonic monitors that are very similar to the one you have.
Here is what I can tell you. The monitor, although it does not seem like it can, be tilted front to back.
If you grip the monitor screen on the side edges (left and right) and 1/3rd the way up and twist it either away or toward you, it should tilt. It is a little stiff, just go ahead and tilt it. As far as adjusting the high. That, I'm sorry to say cannot be done.
I hope this helps you.
Best Regards,
Feb 15, 2011 | ViewSonic VA1912wb 19" LCD Monitor
Can I change the angle of my viewsonic screen
Here is what you can do ergonomically;
Height adjustment range 8.1cm / 3.2", tilt, swivel range 360º
So, yes you can tilt the monitor's angle, but if you are asking about the viewing angles then no you cannot.
May 09, 2010 | ViewSonic VA1930WM LCD Monitor
What is the parts of a monitor
Part Number:RK284AA#ABA
* Display Type LCD display / TFT active matrix
* Built-in Devices Microphone , Speakers
* Width 20.6 in
* Depth 11.4 in
* Height 18.9 in
* Weight 19.8 lbs
* Enclosure Color ( The image of the product displayed may be of a different color )
* Localization English / United States
* Display (projector) image aspect ratio 16:10
* Image Contrast Ratio 1000:1
* Diagonal Size 20 in - Widescreen
* Dot Pitch / Pixel Pitch 0.282 mm
* Max Resolution 1680 x 1050 / 60 Hz
* Max Sync Rate (V x H) 76 Hz x 82 KHz
* On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit
* Controls / Adjustments Tilt
* Tilt Angle 30
* Signal Input VGA
* Digital Video Standard Digital Visual Interface (DVI)
* Type Microphone|Speakers
* Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
* Connections - DVI-Digitaligital , - VGA
* Microsoft Certifications Compatible with Windows 7
* Form Factor Internal
* Voltage Required AC 120/230 V
* Power Consumption Operational 65 Watt
* Power Consumption Stand by / Sleep 2 Watt
* Min operating temperature 41 °F
* Max operating temperature 95 °F
* Operating humidity range 20 - 80%
* Service & Support Limited warranty
* EPA Energy Star Compliant Yes
* EPEAT Compliant EPEAT Silver
Feb 15, 2010 | HP W2007 Desktop Monitor
Tilting Problem with monitor
Screen position adjustment
To optimize the viewing position, you can adjust the monitor tilt by using
both of your hands to hold the edges of the monitor.
The monitor can be adjusted to 15 degrees up or 5 degrees down.
Jun 06, 2009 | Acer 22" X223w LCD Monitor
How to angle the monitor
I have Model X203H & had the same problem. The support CD explained how to adjust the monitor:
Apr 16, 2009 | Acer 22" X223w LCD Monitor
Our viewsonic monitor tilts forward. how do we tilt it back?
Hello again.
The ViewSonic VG1930wm has a height adjustment range of 3.2", TILT capabilities, and a swivel range of 360 degrees.
So yes your monitor should be able to tilt back and forth.  Most likely if you hold the base of the monitor, and press somewhere on the front at the top or bottom (do not press on the screen itself) then it should easily tilt back and forth.  Occassionally there is a switch you may have to hold while you push on the front-top/bottom of the monitor which acts as a lock for the tilt angle.
Hope that helps, and don't forget to vote/rate!
Height adjustment range 3.2", tilt, swivel range 360º
Mar 12, 2009 | ViewSonic VG1930WM LCD Monitor
X2gen MG19E monitor
The only way to adjust the tilt on these monitors is to loosen the screws that attach the stand to the monitor. We had to completely remove the stand from the monitor to get to these stand screws.
Feb 12, 2008 | X2Gen MG19MY 19" LCD Monitor
Screen tiled and i can't move it back
Try reseting the settings to factory defauts in the monitors user menu. You can get more details from the manual on this.
If reseting the settings doesnt work. Could you take a photo so we would have a better understanding of the problem :-)
Or do you mean the screen is fysically tilted? If parts are broken and you are unable to move the screen, then I cant offer much help, you could contact acer for support or to take it to a local pc shop for analysis.
Feb 08, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Screen colors washed out
You can RESET the monitor setting externally by clicking adjustment menu button goto RESET press ok. If contrast and birghtness not set properly light will not be properly visible
Dec 10, 2007 | Samsung SyncMaster 940MW 19" LCD Monitor
Kenwood DNX7100 Car Video Player Logo
156 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
