Question about ON-Q Home 8-PORT Internet Firewall Route Router (F7559)
Unable to print with a brand new iMac. to an HP all in one over an ethernet connection. No luck with a HP technition...he thinks its a network problem. told me to call router tech. The computer and printer are able to "see" each other withIP address. The computer doesn't see the printer without IP address.
Why will my T632 not print over Wi-Fi from my 2011 iMac (10.7.4)?
If the Lexmark T632 is already connected through the Ethernet, it will not be possible to connect it through wireless. The printer cannot be configured with both the Ethernet and the wireless function enabled. The printer will choose the physical connection (Ethernet / LAN) over the wireless connection.
Aug 03, 2012 | Lexmark T632 Laser Printer
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
27'' Imac won't print
try to print and in the print window click the blue button on the left of the top box with hopefully two arrows this should give you the option to choose a printer, follow the prompts when the brother is connected and on and you should get there.
Nov 19, 2009 | Apple Computers & Internet
New iMac very very slow loading pages with Actiontec GT704-WG
I have seen this before and this has cured it:
Check the DNS settings in the Network panel and enter a manual DNS that matches the base address of the router (192.168.0.1 for this router).
System Preferences > Network > Ethernet > Advanced > DNS. Click the + sign and add 192.168.0.1. Click OK, and click Apply on the next screen.
macs2u
Aug 04, 2009 | Actiontec GT704WG Wireless Router...
IMac connection to lanier ld122
Does this printer have the PS option installed? If not you will be unable to print even if you clear up the network issue.
As far as network goes is it currently connected and working with other PCs?
Mac printing is easily setup by typing the IP address of equip in the queue box upon setup. I believe the default queue name is "print" all lower case. If IP in unable to work properly make sure lanier has appletalk turned on and setup printer using appletalk.
Again if the machine doesn't have Postscript option you won't be able to print anything.
Hope this helps,
TankMurdock
Apr 23, 2009 | Office Equipment & Supplies
Unable to connect to Xbox Live!
are you connecting both imac and xbox to the internet at the same time? is your adsl modem a modem/router? and does it have wireless capability?.. if all answer are yes.
assign static ip/subnet mask/default gateway and dns on xbox, then forward 88/3074 on your modem/router.
Nov 08, 2008 | Computers & Internet
My HP Officejet 6310 All-In-One InkJet Printer is unable to complete the network installation
Are you connecting via usb or ethernet cable?
Through usb you need to install the driver on the pc it is connected to. Then share it.
Through ethernet make sure your CAT5/Ethernet cable is connected from your printer to your router/switch. Through the menu on the printer Print the network setup.
Then from your web browser type
http://ip address of printer from the network setup page
If you can then you need to add the printer driver on your pc and use a tcp/ip port to print to it through the network.
Sep 04, 2008 | HP Computers & Internet
ON-Q Home 8-PORT Internet Firewall Route Router (F7559) Logo
52 people viewed this question
Top ON-Q Home Computers & Internet Experts
David Payne
David Payne
Are you an ON-Q Home Computer and Internet Expert? Answer questions, earn points and help others
