Whirlpool GS6NVEXSL Side by Side Refrigerator Logo
Posted on Dec 11, 2009
Whirlpool Gold Side By Side Ice Dispenser Problems
I have Whirlpool Gold Side by Side Refrigerator/Freezer (Model #gs6nvexsl). The ice is generated fine, but will not dispense. The dispenser itself does not make a sound (auger does) when I depress the button for ice. I think (correct me if I am wrong) I have isolated the problem to the ice dispensing motor (PN# AP4410923). Do you think this is truly my problem and if so, how do I replace the motor?
Anonymous
Level 1:
  • Contributor 316 Answers
  • Posted on Mar 19, 2010
Anonymous
Contributor
Level 1:
Answers
316
Questions
0
Helped
105993
Points
21
Instead of what you think the sound is, try and see what is happening when you actuate the ice lever. open freezer door, depress the door light switch, or tape it closed. now actuate the ice dispenser lever, does the flapping door open, that which opens to allow ice from bucket into your glass? Now look at the bucket itself, do you see the gears rotating? remove the bucket from the door, and repeat, do you see the auger shaft rotating?
Either of these are a complex repair, one I would not recommend DIYers to try on their own, for they require taking the door apart, and if not done right, your door may not close properly. Normally I have no problem advising a repair, but there are some i dont, this icemaker system, and compressors.
Visit www.FixMyFridge.net for refrigerator service or to ask general refrigerator questions.
Whirlpool Gold side by side frigerator freezer ice and water not working, inside frigerator various places freeze, on certain shelves units only 5 years old
As far as the icing up sounds like your cross over have ice. Unplug and defrost even on frost free. Should solve both problems
mike
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
1helpful
My Whirlpool Gold side-by-side refrigerator GS6NVEXSL00 wont give me the ice out the door. It makes ice, but when I press the button on the door nothing happens. Seems like the button went out. HELP!
Does the water dispenser work? Is there a light at the dispenser panel, does it light? Do you hear any noises or motors running when you actuate ice dispenser? You could have a power issue for the dispenser. Some newer whirlpool models have an issue with the wiring leading into the door at bottom being so securley fastened to frame, the lack of movement forces the wires to bend, and in time break, with door usage. If water dispenser works, and you hear no sounds when the ice lever is actuated, then you have a problem with the dispenser panel circuit board. if water works and you hear some sounds when ice lever is actuated, such as a loud popping noise, then you have a bad ice dispenser auger motor, not churning the ice out of the bucket.
3helpful
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Whirlpool GS6NBE side by side ice maker works fine but the ice dispenser doesn't. I can hear a sound and a click when I push it and the dispenser flap works but no ice will come out. Water works fine.
The four prong (flat) plug to the ice maker (in the freezer compartment) in my Whirlpool Gold SbyS Refrigerator; should I be able to test for 120 Volts with a tester, should this plug be 'HOT"?
2answers
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
6helpful
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
