Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Need to be able to stream
Hi i need to be able to stream to my shoutcast through samsbroadcaster and it will not let me...
I think it has something to do with my router blocking could you please help
Jenn
Hi i have a router model befsr41 i cannot access my firemware can you help ?
Posted on Feb 14, 2008
    Novelist:
  • 173 Answers
This patrticular b router from linksys is a older version, it is not compatible for certain products, try upgrading the latest firmware for the router through, www.linksys.com/downloads, or else replace the router and check..
Posted on Jan 21, 2008
6ya staff
SOURCE:
My streamer worked fine until we moved and put it in storage now it connects to internet then when you try to do something with the remote it says prohibited
Try running the basic set-up procedures. If it's connected to a wireless network, you may have to enter a password (if one was set up and network security is turned on) in order to connect to your router / wi-fi network.
BTW, are you using the remote to access netflix? I don't think that the problem is with the remote, you're probably trying to access sites that require subscriptions and log in info to access the streaming media.
Mar 01, 2015 | RCA DSB772WE Wi-Fi Streaming Media...
Does anyone know out to connect a chrome cast to a sky router
Hi Peter, not sure what you are trying to do here but the ChromeCast dongle needs to plug into an HDMI port on your TV. It has a microUSB port only for power.
On some routers, there are USB ports for 3G dongles for wireless broadband, or media storage for DLNA or media sharing on your local network.
If you are trying to get eg. Youtube through your router, check this compatibility list:
Google Cast Router Compatibility
Hope this helps.
Nov 18, 2014 | Google Chromecast HDMI Streaming Media...
I would like to know if there is a way, to broadcast from a web cam to another web site. I am a member of Utherverse, and I own a club. I want to do my own DJ, and video. Is there a way I can use a...
Install Winamp on your laptop you have you music that you going to stream.. install shoutcast DNAS server, configure it with a username and password.. when you fire up winamp, shoutcast DNAS should open together and you click connect on DNAS.. its going to broadcast your music.. you can also broadcast a picture of yours on the mix.. you can also configure it to sync with Virtual DJ..
May 13, 2011 | Computers & Internet
Windows Media Player 12 Streaming Radio Issues
go to option (near file menu ) reset it to default setting..... ask more if u don't get it right
Mar 29, 2009 | Microsoft Windows Media Player
How to Design a radio player in website by using javascript?
shafihot SERVER ERRROR Solution
How To Make Your Own Radio Station
Must HAVE Winamp (Any Version)
First, things First your speed has to be at least 256/64 kbps (which means Dial-up users, will have alot of latency, just dnt bother)
Second, your going to have to have a domain, an updated one with the current i.p active. (Could be anything e.g. My sig)
Now, Your gonna have to download the Shoutcast Files.
Go to www.shoutcast.com to get the files.
Ok After downloading these, installing Both of them in any order i dnt care. Go to START>PROGRAM FILES>SHOUTcast DNAS>EDIT SHOUTCAST DNS CONFIG.
Ok your gonna have to Configure it:
Go Down and where it says password: change (that means your gonna have to change it to whatever, make sure u remember)
The Portbase: change it to whatever port you want it
Maxusers: (lets be realistic here, dnt put in 10000, like NXS's radio station) your bandwidth has to be extremely good, if your cable, 50 user max is ok, ADSL should stay below 10 users, and T1 connections should do whatever tickles there fantasy.
Open winamp, RIGHT CLICK>OPTIONS>PREFRENCES>DSP EFFECT> and choose the NULLSOFT SHOUTCAST.
Go to OUTPUT, and then click on Connection, Through the ADDRESS, type your address which you have done through www.no-ip.com, PORT NUMBER, whatever u did in the EDIT.txt, and your password.
Then go to Encoder, and choose your quality of your music. Go back to OUTPU>OUTPUT CONFIG> YELLOW PAGES. this is your advertisemant information. dow hatever you like there.
Now Connect. to check that your Radio os on-line go to http://(your address that you added in the prefrence)
more detailes...
help
mail me [email protected]
[email protected]
Jan 31, 2009 | Computers & Internet
I want to use my hp g2 server to set up an internet radio station
Ah , I have been down this road myself :-) ...... I can give you a few words of advice......
  • As far as the server itsef , it really doesn't need anything spectaculer in regards to hardware & specs.....a box running XP with 512mb of RAM would suffice...so your server should be fine
  • Bandwith - you are going to need ALOT of it if you are streaming more then 64kb's....typically if you are playing any sort of music you stream at 128kb....so make sure you have a hefty data plan!
  • For the server itself , use the "Shoutcast" software for hosting the station....it is easy to use , has plenty of support and documentation....you can literally have a station up in 5 mins!
  • For broadcasting you can use the Winamp program with the "Shoutcast DSP" plugin...but if you are playing alot of music , want advertisments and like to DJ I would recommend something like "SAM 4"
Just a quick overview to get you started , all you really have to do is download the shoutcast server software , edit the config file - which includes the admin password , the port to broadcast on , the max number of listners you want etc..........
You then need to do some port forwarding, opening up the port on your router and sending the connections to your server....actually doing it is easy, but it varies by router model, you can use this site for a step by step, just select your router , and then select "Shoutcast" http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
From there you launch the server program , and connect to the server with Winamp or SAM....and now your on the air!
SHoutcast documentation to setup DJ and server:
http://shoutcast.com/download
I have alot of exp. with this , you didnt really specify a specfic problem or question , so if you need anything else be sure to leave a comment here and I can help you even more!
Oct 02, 2008 | Computers & Internet
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
63 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
