Question about Bushnell ® Elite® 3200 3 - 9x40 mm Ballistic Reticle Riflescope
My scope is fogging up on the inner lense not outer lense
  • 2,418 Answers
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trash can size. You will need to get your hands on some nitrogen gas or you can also use carbon dioxide gas. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off of your scope, (This means unscrew it from the scope body) let it dry out a day or so. Now ck for any o-rings on the scope body some will have a small o-ring - like a good flash light the good metal kind, and try to find new if it has one if you can, put the grease on the screw threads. Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 14, 2009
Why do need a waterproof spotting scope?
Many activities that include the use of scopes such as binoculars, spotting scopes and riflescopes take place outdoors, often in damp, humid or foggy conditions. Having waterproof binoculars, spotting scopes or rifle scopes will eliminate your concerns about moisture damage, including fogged over inner optics that are sure to ruin your day out! Some waterproof binoculars can even withstand short submersion's in shallow water so even accidentally dropping them in a puddle on a hike won't matter.
Apr 16, 2018 | Optics
Which is the good spotting scope for higher amount of light?
Bushnell Trophy Xtreme Spotting Scope
Overview
Bushnell Spotting Scope has extra power for extra range; its BaK-4 Porro-prism design delivers magnificent clarity in a traditional design. The multicoated optics ensure maximum light transmission for the brightest and take the images more colorful and clear. If you are searching Bushnell Scope that can be used for different activities, you should consider Bushnell Trophy Xtreme Spotting Scope Review.
The highly refractive BAK4 Porro prisms diminish spherical deviations for increased edge-to-edge sharpness and help progress depth of view. This combination of optics and coatings creates a spotting scope that produces clear, bright, highly contrasted images with the exact color transmission.
The rubber-armor structure stands up to demanding use. This scope is 100% waterproof and fog proof for wet hunting conditions. It also Comprises compact tripod with window mount, compact soft case, and waterproof hard case.
Specifications
  • Brand:Bushnell
  • Viewing Configuration:Straight
  • Magnification:16-48X
  • Power Variability:Variable
  • Objective Diameter:50 mm
  • Close Focus Distance:25 feet
  • Length:13 inches
  • Weight:31.4 ounces
  • Field of View:125-60 feet/1000 yards
  • Eye Relief/Exit Pupil:16 mm/ 3.1-1 mm
  • Optics Coatings:Fully Multi-Coated
  • Glass:BaK-4
  • Focus System:Focus Knob/Single Focus
Feature Analysis
  • Porro Prism Lens
    Though many optics producers keep on trying to transform roof prism lens, Porro prism lenses are more affordable and light-efficient. These Porro prism lenses can display images with better contrast than roof prism variations. This is how Bushnell Spotting Scope is more reliable and affordable for its high-quality performance.
  • 20-60×65 Zoom Magnification
    The wide range of magnification allows user flexibility for long-range view finding. You can observe details with 65x zoom for long range objects. But, you can still enjoy an increased field of view with 20x zoom. This is used when separating the areas for closer zoom viewing later on.
  • 65x Lens Light-Gathering Capability
    This advanced magnification lenses can light gather at long distances. The Bushnell Trophy 20-60x 65mm Waterproof Spotting Scope resolves this issue by designing 65x zoom lens in a way that brings 17% more light than most high-zoom lenses.
    If you fully read Bushnell Trophy Xtreme Spotting Scope Review, it will support you how to setting zoom for longer distances images.
  • Waterproof Construction
    When you go out in nature, this waterproof construction anticipates you about rain or even snow. It is pretty obvious that any liquid that leaks into your scope will detract from the overall image. But many people do not consider the effects of concentration on the inside of the lens.
    This spotting scope is actually water and fog proof not only for outside moisture but also prevents lens fogging from risky temperatures.
  • Fully Multi-Coated Optics
    The multi-coated lenses prevent any reflections in the glass that can delay your view. The sunlight at certain angles can cause reflections from water or wet surfaces that prevent the clear view of the images. That is why; Bushnell uses multi-coated lenses to remove any kind of reflection.
  • Well-designed Equipment
    The tripod often needs to hide from animals, and the scope cases also need to protect their insides from both jostling and the outside elements. The Bushnell Trophy XLT comes with both a hard-side case and a soft side case. The hard side case protects you from outside damage and a soft-side case protect you from a bumpy road when you are riding.
Mar 18, 2018 | The Optics
When I look through my scope I can't ever get into focus. I have other people look through it also with the same results. The scope fogs up now in cold weather also
there is an air leak on this scope and bamp air has got inside it,,all you can do is strip the scope out clean all the lenses and re-gas it,,,,to be honest,,,its a bust bin job now!
Aug 24, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
The two front lenses are fogged up. What can I
It gets condensation from going cold to hot, you can't take them apart without disturbing the seal. The only thing you can do is put it on the radiator and let it warm up, slowly, evenly, not too hot, for about a week. My gps on my bike fogged up and it is in the sun all day, but still won't dry out, so, you are taking a chance. It might not do anything. Hope this helps.
Mar 08, 2010 | NcStar Illuminated A.O. Rifle Scopes -...
Scope is fogging up
Either use an anti-fog wipe on it, such as Scope Dope... or don't breathe heavily on your lenses!
Jan 01, 2010 | Tasco Hunting World Class Scopes Standard...
Telescope is fogging up after a couple of hours hunting, very fustrating when you have a moose in front of you and you depend on your scope only, can you help. i have a deerfield3-9+32 wide view on a...
the scope is fogging up because there is a moisture problem. The lenses have to be removed so that everything thoroughly drys out and then the o rings have to be lubricated so that they are total barriers to outside humidity.
Oct 15, 2009 | Optics
Whitch way do my lenses go?
If you completely disassembled the scope then it is compromised they have a special gas mixture inside for fogging and clarity so if they were removed you are likely better off with a new one out of reference what kind of scope is it
Apr 02, 2009 | Hawke Sport Optics Hawke® Endurance MAP 3...
Fog light bulb replacement
This bulb can be replaced without removing the washer fluid reservoir. There are 3 screws that go through the bottom edge of the bumper cover into the right inner fender guard. Remove these screws and pull the inner fender down to gain access to the back side of the fog lamp and remove the bulb.
Nissan Scope Technician- 10+ years experience in Nissan dealership.
Nov 04, 2008 | 2003 Nissan Murano
Lens Fogging Issue
Apparently this is NOT a waterproof rifle scope. I would return it as you will have this same problem only worse out in the field. Buy a waterproof nitrogen filled rifle scope.
Dec 06, 2007 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Internal cleaning
I don't know about disassembling binoculars. However have you tried drying them out, either in a "dry box" or by using silica crystals?
May 06, 2007 | Tasco Essentials 10x50 2023BRZ Wide Angle...
Bushnell ® Elite® 3200 3 - 9x40 mm Ballistic Reticle Riflescope Logo
188 people viewed this question
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Goldi Kunal
John Hermes
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
