Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv snow for first 5 minutes on
My Sony Tv has snow for first 3 to 7 minutes when first turned on then once the picture comes on is fine until tv is turned off then same problem each and every time when first turned on. Tv is 27 in cabinet model about 10 or so years old.
  • 1 more comment
  • RegisCurry Jan 20, 2008
    Thanks.....but can you tell me where the tuner section is and how to fix it? I have read before that the solder joints may be faulty and I bought a cold heat soldering gun and electical solder but have been leery of taking the back off of the tv and trying to repair it.
    However, it is almost impossible anymore to find a tv repairman so if I could get some assistance in what to do I could try to fix the problem myself.
  • RegisCurry Jan 21, 2008
    Thanks for the info. Needless to say, I will not be trying to fix it myself. Appreciate that you pointed out the hazards.
  • bill bones Mar 09, 2008
    I apparently have the same problem with my 1994 model Sony KV20S10 Trinitron color TV. Only my TV make take "MUCH" longer then 5 minutes to come on. When it does come on the picture/sound quality are near perfect. "Keever" responded to check the 'cable-off' item in the menue since I'm on local antenna but that was done longgggg ago.
    Has your problem been corrected at this time? Check my Bill Bones question.
    Scholar:
  • 110 Answers
Probably dry solder joints in the tuner section.
When the set warms up, the faulty joint/s make contact, then lose contact again when it cools down.
Posted on Jan 20, 2008
  • digiteyes Jan 21, 2008
    The tuner section is usually contained in a small metal box which in turn is mounted on the main board, where the antenna connects.
    Standard-size soldering irons are usually way too large as the components are the surface mount type and require a SMC iron.
    Using a standard soldering iron can easily short out other components. You may also need a circuit diagram, a multimeter and/or oscilloscope and obviously, a full understanding of how to use such test equipment.
    Apart from this, there are extremely dangerous voltages that remain in TV's, long after they have been turned off (around 25 thousand volts). If you are not experienced in TV chassis repair, I strongly advise against attempting any DIY repairs for safety reasons alone.
6ya staff
SOURCE:
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
80GB PS3 displays Snow/White screen during playback
Did you ever figure out how to fix this. We simply took our system and hooked it up to a different tv and it stopped. I personally think the problem is with the HDMI cable and wether the cable and the socket are connecting.
Aug 29, 2009 | Sony Playstation 3 (PS3) Console
Sony WEGA
It is TV problem in Tuning section hardware.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Sony Trinitron TV Snow
I found out accidentally, is when I push the "demo" button, which shows many of the features on the TV. It'll run through the demo a few times, for as much as 10 minutes, then the TV will be fine. as you are getting fine picture on demo it indicates that your tv is perfectly ok. problem is out side of tv 1 check cable connection for loose or its socket is loose. 2 wire might be old or defective. 3 check tunning is done properly 4 if every thing is fine then check for tuner in your tv. good luck
Sep 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
87 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
