Question about Acer TravelMate 4010 Notebook
LCD is on...seems like backlight is not functional; when external monitor connected, boot-up and bios screen visible. After boot-up, screen goes to "power save" mode and will not return
    Brigadier General:
  • 10,406 Answers
Use the 'FN' key (blue coloured?) and one of the other blue-coloured keys to "toggle" the video:
1. LCD only
2. external monitor only
3. both LCD & external
After boot-up, Windows defaults to "LCD only", and so the external monitor goes to "sleep".
Posted on Dec 11, 2009
Hp pavilionn dv6700 screen goes black after a while
If you shine a flashlight on your black screen and look real hard for the icons on the desktop. If you can faintly see them that means your LCD Inverter is bad. You'll have to disassemble the LCD Screen to get to it. In the mean time you can attach another monitor (LCD Flat Screen or the Old style fat CRT) with a VGA cable to the vga port on you laptop. Once you have it connected hit the FN (Function Key) + (F1 thru F12) key that that corresponds to the external display. Hold the FN Key while you hit the Function Key that is for the external display. The key might have the words LCD/CRT on it or it might show a display symbol. That's the key you want to hit while holding down the FN key. This will cause the desktop to display on the external monitor and verify that there is no problem with your Video Card inside the laptop.
Mar 15, 2012 | Computers & Internet
LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Jun 07, 2008 | Compaq Armada M700 Notebook
My HP compaqnx9600 laptop screen display verticle lines, how can i remove them
Here are some steps that you can try.
- Hook up an external monitor.
- If the line is visible on the external display, try to update your video card driver. But if updating the driver will not remove the vertical lines, you are certainly having problem with the video card of the laptop.
- If the line is not visible, then the problem is with the LCD of the unit. Either you have to replace or check the connections of the LCD inverter or LCD cable.
- However, if you don't have any external monitor, go to BIOS setup (by pressing F10, or whatever key is designed to access the BIOS on your laptop) and check if the line is visible, if yes, you're having an LCD/screen problem. Either you have to replace or check the connections of the LCD inverter or LCD cable.
Hope this helps.
May 30, 2011 | HP Compaq NX9600 17.0-inch WSXGA+...
I have a tecra m2-s730 that displays the boot screen then back light goes out but you can still see image..what could be problem
1) test it to an external source like a tv, or external monitor through the vga ports, svideo ports. If promblem is solved, and everything seems to be going normal, then your screen is history, bad backlighting and needs screen replacement. 2) Bootup screens seems to work fine, ( like it has backlighting and light all work fine and normal) but when it turns over to loading your o/s and it get dark even with a external monitor, then it's a driver issue or your vga chipset is bad and you will need to replace your motherboard, ( in this case it is best to buy a new laptop). 3) Bios error issue, bios has become currupt somehow, you can try loading default value given in the exit tab in your bios menu. Load and save and exit. See if it works, if not your VGA chipset is screw, and motherboard will need to be replaced to fix this issue.
Jan 30, 2011 | Toshiba Tecra M2-S730 Notebook
Black screen on booting my Compaq 610 notebook
If it seems like you're accessing the hard drive (drive light comes on, flickers intermittently, then goes off, it's a good chance your screen is bad.
First thing to do is plug in an external monitor and start up the laptop. If it comes up with windows, you know it's the screen.
To find out if it's the backlight, or the lcd, toggle the monitor function and shine a flashlight on a slight angle to the screen. If you can faintly see what was displayed on the external monitor, then the backlight inverter is probably bad.
If the external monitor didn't come up, you're probably looking at a motherboard.
The good thing is that all of those are covered for one year under Compaq's warranty, on a new machine.
If you are able to use the external monitor, back up your data, because HP/Compaq usually reformat the harddrive. Additionally, if you've added memory, pull the cards. They want it sent back the way it came from the factory.
Jan 09, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hi my screen has gone blank on my laptop advent 5431 any ideas
I have gateway mx7118 and my screen went dim when power on. I connected to a external monitor and no pic on the monitor.
Could the problem be I need to replace the LCD invertor?
Nov 29, 2009 | Acer Aspire 4720 Notebook
My lenovo Y510 ideapad turns on but the screen remains black. All of the buttons light up, but the screen stays like it is in sleep mode. I have tried rebooting, removing the battery but nothing seems to...
The next tim eit is turned on, try shiniing a bright flashlight directly on the screen.
If you can see anything there then the backlight has burned out on the screen, and will need to be replaced.
If you cant see anything, try hooking up an external monitor to the laptop, if you have a desktop the monitor for it will work for the test..
If the external monitor you hook up will work, then you will have to replace the screen..
( or at a minimum the inverter board, or check that the cables are tight that go to the screen)
Oct 31, 2009 | Lenovo IdeaPad Y510 Notebook
Satellite A25-S279 screen flickers and goes blank after 5-10 secs
are you getting image on your LCD while booting up in the bios and windows loading screen ?
if yes, then perform a windows installation.
Aug 24, 2009 | Computers & Internet
I have a Acer Ferrari 4006wlmi it boots and
Hi...
You need to reinstall the OS.
Let me know
Thanks
Smith
Aug 09, 2009 | Acer Ferrari 4006WLMi Laptop Notebook
When the Sony Vaio laptop is powered up there are missing(dark)
Connect an external monitor to the video connector on the laptop and bootup the laptop. If you don't get an image on the external monitor then press the blue Fn key plus the one of the function keys with the screen/monitor symbol, (this toggles the display between the LCD and external video connector).
If you cannot get an image then the you have a faulty video card. The video card is part of the motherboard and cannot be fixed, you have to get a replacement motherboard.
When you boot up without the external monitor and you look at the LCD from an acute angle and you can see a slight and dark image, this indicates you have a backlight problem.
The image on the external monitor indicates that you have a faulty inverter that provides power for the backlight panel or a faulty backlight panel, the inverter and the LCD panel can be replaced fairly easily but it is not cheap, but it would be cheaper that buying a new laptop.
If the external monitor works and you can use it this way, this would be the cheapest option, but it would not be portable.
Feb 11, 2009 | Sony VAIO PCG-K23 Notebook
Acer TravelMate 4010 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
